SolaraGuy.com • View topic - Will 19" fit on the TRD version
Postby G_Unit » Fri Jul 25, 2003 2:50 pm
I am wondering if 19's will fit on a the TRD version solara, also what is the widest tire size I can go, and also are spacers good or bad, and i really dont want my car to look like a rollerskate!
G_Unit
Postby STR8PYP » Fri Jul 25, 2003 3:24 pm
www.schung07.com
Offsets are +44/+38 nominal (yes, diff offsets front and rear).
19x8.5 max size, 235/35R19 max tire size.
I'm using spacers in the rear (and shaved the fenders), haven't had any problems.
SC
STR8PYP
Postby xXsolaraXx » Fri Jul 25, 2003 4:16 pm
if you dont want spacers...what do you recommend?
19"s that is...
xXsolaraXx
Postby STR8PYP » Fri Jul 25, 2003 10:18 pm
19x8.5, +38 and +44 offsets (staggered front and rear), 235/35R19.
I only used spacers because I wanted the same offsets all around, so that they can be rotated. With staggered offsets, you cannot rotate the tires.
SC
STR8PYP
G-racing Kobe's
Postby DonJuanCU1 » Sat Jul 26, 2003 7:56 am
I just ordered the G-racing Kobe 19"s with 235/35/19 toyo's. how much of a problem will there be if the car isn't lowered yet? i'm pretty sure the wheels are only 19x7.5 so they're not as wide as yours but i'm just checking.
'99 V-6 auto, 19" G-racing Kobe's with Toyo Proxes, injen intake, pioneer head unit, mtx thunder6000 subs, 600W digital Alpine amp, Showoff Xenon Blue headlights and foglights and PIAA blue foglights in air dam. Clear corners and reverse gauges.
DonJuanCU1
Postby STR8PYP » Sat Jul 26, 2003 2:24 pm
Fitment should not matter whether the car is lowered or not. If you get the right size and offset, the wheels/tires will fit regardless.
SC
STR8PYP
