SolaraGuy.com • View topic - recalls?
recalls?
recalls?
Postby 5sfe » Sun Oct 18, 2009 12:45 pm
any recalls were made on the solara?
5sfe
Postby solara90 » Sun Oct 18, 2009 1:48 pm
i found this
Recall Date:
JUN 05, 2000
Model Affected:
2000 TOYOTA CAMRY SOLARA
Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. DUE TO IMPROPER HEAT TREATMENT, THE REAR AXLE MAY NOT HAVE ADEQUATE STRENGTH IN SOME AREAS.
Consequence:
AFTER EXTENDED USE OF THE VEHICLE, THE REAR AXLE SHAFTS COULD FAIL OR BREAK.
Remedy:
DEALERS WILL INSPECT AND REPLACE THE REAR AXLE HUB ASSEMBLIES.
Potential Units Affected:
541
Notes:
TOYOTA MOTOR NORTH AMERICA, INC.
And this
Recall Date:
DEC 21, 2006
Model Affected:
2007 TOYOTA CAMRY SOLARA
Summary:
ON CERTAIN VEHICLES EQUIPPED WITH CURTAIN SIDE AIR BAGS (CSA), THE CSA TETHER STRAP LOCATED IN THE FRONT PILLARS MAY HAVE BEEN INCORRECTLY ROUTED DURING THE ASSEMBLY PROCESS.
Consequence:
IF THE TETHER STRAP IS NOT CORRECTLY ROUTED, THE FRONT SIDE OF THE CSA MAY NOT DEPLOY AS DESIGNED, WHICH MAY RESULT IN INSUFFICIENT OCCUPANT PROTECTION DURING A SIDE IMPACT CRASH OR ROLLOVER EVENT.
Remedy:
DEALERS WILL INSPECT BOTH CSA FRONT TETHER STRAPS, AND IF NECESSARY, REROUTE THEM. THE RECALL BEGAN ON DECEMBER 21, 2006. OWNERS MAY CONTACT TOYOTA AT 1-888-270-9371.
160
Notes:
TOYOTA MOTOR NORTH AMERICA, INC. 60J
02 solara 2az
solara90
Postby GreenSolara01 » Sun Oct 18, 2009 4:44 pm
You think they fixed that by 2001?
GreenSolara01
