SolaraGuy.com • View topic - 2000 solara i4 - length of solid extension bar for plugs
Postby feniks » Mon Oct 19, 2009 8:39 am
hello people,
so far i've been using a flexible extension bar for my 3/8 ratchet and spark plug socket. i would like to use a solid one as it allows to torque the plugs down more precisely (you never know how much torque a flexible extension bar transfers to socket below).
problem is that design and placement of i4 (2.2L 5S-FE) engine in my 2000 Solara makes it hard. reason why i used a flexible bar in first place is that above spark plug holes is a metal crossbar going across the engine compartment. solid extensions bars i have were either too long (crossbar blocks access) or too short (plug cannot reach the thread).
and here I am asking experts :) which extension bar length works best for you ?
'02 Solara SLE 1MZ-FE/A541E Coupe .: Denso : Akebono SP : HIR :. @ 125k
'00 Solara SE 5S-FE/A140E Coupe .: NGK : Hawk HPS : Philips Xtreme : RC : Magnefine :. @ 79k
feniks
Postby Chinky420 » Mon Oct 19, 2009 9:24 am
why not just unbolt the crossbar (strut tower brace?) and then use whatever you're comfortable with?
seems to me that this would be the easiest route to take.
Chinky420
Postby feniks » Mon Oct 19, 2009 9:33 am
it is a thought. however i'd rather keep it simple and avoid unbolting the crossbar.
feniks
Postby Gibson99 » Mon Oct 19, 2009 9:54 am
i think i used a 6" extension on them when i was working at toyota. if not, then i used a wobble extension. they let you pivot about 10 degrees in the socket itself, and may give you just enough room to clear the strut tower brace.
this is what i have: http://www.harborfreight.com/cpi/ctaf/d ... mber=31203
just don't try to use them on an impact gun ;)
Gibson99
