SolaraGuy.com • View topic - Running No PCV...
Running No PCV...
Running No PCV...
Postby Slut » Mon Oct 19, 2009 8:42 pm
Any thoughts on making the pcv a breather? Ive been trying to look into it.. Or even put an extra breather on the other side of that valve cover with the PCV? I am boosted and I rather let as much pressure out as I can... and I know the PCV will close with no vac. What the the pros and cons? I couldnt see adding another breather to the rear valve cover bad?
Slut
Postby Gibson99 » Wed Oct 21, 2009 10:43 am
if you have the trd sc, the pcv will be fine, as it's routed over to the intake side of the s/c - if anything, it will pull MORE of a vaccuum on the motor under boost. that's why you have to run that long hose around to the other side.
i don't recommend a breather as it will just make a mess on your valve covers.
Gibson99
