SolaraGuy.com • View topic - P0773 A/T Shift Solenoid 'E' (SL) Circuit Malfunction
Postby Anthony » Mon Oct 19, 2009 10:48 pm
Hey everyone,
My check engine light seems to turn on and off randomly. The code that comes up is:
I went to a couple of transmission shops, but they seemed more interested in replacing the entire valve body or rebuilding the transmission all without even taking the car for a spin.
As far as I can tell, the car runs and shifts perfectly. The mileage is currently about 250,000 km. I bought an OBD2 car reader and got the information below. Can someone let me know what they think?
Freeze Frame Information
Parameter Description Value
DTC for which Freeze Frame was Stored P0773
Fuel System 1 Status Closed Loop
Fuel System 2 Status Closed Loop
Calculated LOAD Value 24.71 %
Engine Coolant Temp 185.00 °F
Short Term Fuel Trim - Bank 1 -1.56 %
Long Term Fuel Trim - Bank 1 -1.56 %
Short Term Fuel Trim - Bank 2 -1.56 %
Long Term Fuel Trim - Bank 2 -0.78 %
Engine RPM 1,452.00 rpm
Vehicle Speed Sensor 33.55 mph
Intake Air Temperature 82.40 °F
Thanks in advance for your help!
Anthony
2002 SLE V6
Anthony
Postby ThatVietGuy » Mon Oct 19, 2009 11:43 pm
ThatVietGuy
Postby akora12 » Tue Oct 20, 2009 5:02 am
I've seen this code thrown several times in the auto 1MZ's. You'll be fine to drive on it until you get a chance to fix it.
