SolaraGuy.com • View topic - CEL... help
CEL... help
CEL... help
Postby SolaraMan7890 » Tue Oct 20, 2009 9:40 pm
So, changed the oil, and checked the air filter, then had to remove battery, then reconnected it again... about 5 miles later, CEL comes on... P1130.
Anyone?
2000 SE.
SolaraMan7890
reply
Postby NRDriver » Tue Oct 20, 2009 9:58 pm
i believe that is o2 sensor 1/1 failure
thats the o2 sensor right near the oil filter. check for any damage to it
NRDriver
Postby ThatVietGuy » Tue Oct 20, 2009 9:58 pm
ThatVietGuy
Postby SolaraMan7890 » Tue Oct 20, 2009 10:30 pm
Any idea how to fix? sorry i'm a noob when it comes to this stuff...
2000 SE.
SolaraMan7890
Re: reply
Postby SolaraMan7890 » Tue Oct 20, 2009 10:31 pm
NRDriver wrote:i believe that is o2 sensor 1/1 failure
That's P0130
according to the description, its
P1130 A/F Sensor Circuit Range / Performance Malfunction (Bank #1 Sensor #1)
2000 SE.
SolaraMan7890
Postby Chinky420 » Wed Oct 21, 2009 9:29 am
i'm thinking it may be the same sort of code, except you may have a cali-spec solara (uses A/F sensors instead of oxygen sensors)
you can confirm if you have a fed-spec or a cali-spec car by checking the ID sticker under the hood (you know, the sticker that also shows the serpentine belt diagram)
or you can take a picture of your manifolds and post them up, and someone around here should be able to confirm whether or not you're fed- or cali-spec.
and if i'm not mistaken, bank1 is the rear bank (side that cylinder 1 is on), and the sensor is gonna be between the engine and the firewall.
replacing it is the only solution i know of.
Chinky420
Postby SolaraMan7890 » Wed Oct 21, 2009 11:48 am
Carfax said that the first three owners of my Solara were in Cali... I think it might be safe to say that it's Cali-spec.
Can anyone quote me an estimate of how much it is going to cost to take care of this A/F sensor?
2000 SE.
SolaraMan7890
Postby Chinky420 » Wed Oct 21, 2009 2:22 pm
anywhere from a couple to a few hundred bucks (those specialty cali sensors were much more expensive than the fed-spec $60 denso O2 sensors...i wanna say the a/f sensor is like $240)
check autozone, make sure you look for A/F sensor and NOT oxygen sensor.
yeah, the more expensive one is the one you're looking for.
as far as labor costs, it shouldn't take a shop more than an hour to do (it's possible to do yourself, you'll need to get an offset oxygen sensor wrench-socket, which is also carried at autozone, and i think there's a DIY writeup in the tutorial section).
Chinky420
Postby SolaraMan7890 » Wed Oct 21, 2009 3:08 pm
Chinky420 wrote:anywhere from a couple to a few hundred bucks (those specialty cali sensors were much more expensive than the fed-spec $60 denso O2 sensors...i wanna say the a/f sensor is like $240)
:o :o :o
on second thought, maybe i'll check the spec of my car, before assuming... :roll:
2000 SE.
SolaraMan7890
Postby SolaraMan7890 » Wed Oct 21, 2009 10:29 pm
Are you sure that I can't just replace it with the O2 sensor? I heard that it's the same thing...
... and autozone only has O2 sensors not A/F sensors.
2000 SE.
SolaraMan7890
Postby Chinky420 » Thu Oct 22, 2009 12:53 pm
if you're cali spec you HAVE to use the A/F sensor
if you're fed spec you would use the oxygen sensor
Chinky420
Postby SolaraMan7890 » Thu Oct 22, 2009 9:00 pm
Cali-spec...
big CAL letters on the sticker that's on the bottom side of the hood...
2000 SE.
SolaraMan7890
Postby SolaraMan7890 » Sat Oct 24, 2009 10:44 am
UPDATE> After not driving my car for 5 days, I got in last night, and no CEL. I didn't have it reset or anything...
What does that mean?
2000 SE.
SolaraMan7890
Postby lilm » Sat Oct 24, 2009 12:28 pm
maybe it was just a glitch
lilm
Postby Chinky420 » Mon Oct 26, 2009 9:46 am
maybe the a/f sensor just needs to be cleaned, or maybe the wires where the plug is are coming loose?
Chinky420
