SolaraGuy.com • View topic - gged my ebrakes
gged my ebrakes
gged my ebrakes
Postby MiistahSaan » Mon Nov 02, 2009 10:47 am
So i was driving home from the bay the other day. and i was sleepy so i stopped at the gas station. i believe this is wen it started, im not exactly sure. so i was pulling out to the freeway and was wondering why my car was soo slow. so i just kept pushing it a lil and i was probably going 70 on the freeway more or less. i had my sunglasses on so i dindt realize my ebrake was on. after realizing this, i took the ebrakes off and now. when i brake. my car shakes and makes a weird sound. mostly in the right side of my rear brakes. my uncle said i need new drums. do i need everything else? what do i need?
driving with ebrakes on. fml
MiistahSaan
Postby Gibson99 » Mon Nov 02, 2009 10:58 am
yup, you'll need new drums and shoes in the back, likely on both sides. if it's a v6, you will need the rotors (since the parking brake is a small drum inside the center of the rotor) and shoes, but you won't need disk pads.
but since you say it makes noise and shakes while braking, i'm gonna guess you have a 4cyl which doesn't have drum-in-disk.
Gibson99
Postby amp3188 » Fri Nov 06, 2009 11:38 am
I've never had an issue with that in my solara, but it sounds warped. I find the solara's to be very generous with the e-brake though as I have used it on numerous occasions to slide the car around in the snow.
1999 V6 SLE Red Solara - 247,xxx
2003 V6 SLE Black Solara Convertible - 167,xxx
amp3188
Postby vman5911 » Wed Nov 11, 2009 2:26 pm
amp3188 wrote:I've never had an issue with that in my solara, but it sounds warped. I find the solara's to be very generous with the e-brake though as I have used it on numerous occasions to slide the car around in the snow.
I've used it to slide around on the regular street lol
vman5911
Re: gged my ebrakes
Postby Midias » Wed Nov 11, 2009 3:30 pm
MiistahSaan wrote:So i was driving home from the bay the other day. and i was sleepy so i stopped at the gas station. i believe this is wen it started, im not exactly sure. so i was pulling out to the freeway and was wondering why my car was soo slow. so i just kept pushing it a lil and i was probably going 70 on the freeway more or less. i had my sunglasses on so i dindt realize my ebrake was on. after realizing this, i took the ebrakes off and now. when i brake. my car shakes and makes a weird sound. mostly in the right side of my rear brakes. my uncle said i need new drums. do i need everything else? what do i need?
If you are drums on the back get shoes, drums and a full HW kit. For disks get rotors inner shoes and a full hardware kit. Personally I had a damn hard time finding the Hardware kit for my V6 only pepboys carried it.
