SolaraGuy.com • View topic - Are the rear turn signal bulbs 3156 or 3157????
Postby trd4life » Tue Nov 03, 2009 2:25 pm
My Toyota manual says 3156 the parts stores i have checked all told me 3157. And, the 3156 doesn't even fit in the socket, error in the toyota manual?
Postby krook » Tue Nov 03, 2009 7:28 pm
i'm pretty sure it's 3157.
i think 3156's are only ONE filament. our tail/brake lights are dual filament, meaning they light up with parking lights and flash brighter when the brake is pressed.
krook
Postby LEE337 » Tue Nov 03, 2009 11:06 pm
3157- dual circuit
Same as the front turn signal/parking lights
They work the same way as the tail/brake lights
When you turn on your headlights your tails and corners come on.
Then cuz its a dual circuit it gets brighter when you tap the brakes.
Same as the corners. When you turn on your signals it flashes brighter to indicate a turn.
