SolaraGuy.com • View topic - keyless entry beeps
keyless entry beeps
keyless entry beeps
Postby 02slera » Mon Nov 09, 2009 2:16 pm
my car is a 02 solara sle with basic keyless entry. my understanding is that when the doors are locked it should beep once and when unlocked it should beep twice. instead of beeping my lights flash once or twice for lock or unlock. the owners manual says "switching beep sound on and off"....
with driver's door opened;
insert the ignition key and remove it;
within 5 seconds, insert the ignition key again and turn it to the "ON" position;
after 10 seconds, push the same "LOCK", "UNLOCK", "PANIC" or trunk opener switch twice within 10 seconds. two beep sounds inform you that the program has been switched on or off.
This is not working for me, anyone know of a different procedure or anything i can check?
2002 Solara SLE v6
02slera
Postby 02slera » Wed Nov 11, 2009 8:02 pm
bump pending issue
2002 Solara SLE v6
02slera
Postby TLMNICK » Wed Nov 11, 2009 8:13 pm
If you leave a door opened, and press "lock" on the remote, do you get a long "beep" noise from the car? (and I dont mean from the horn).
If you don't get it, then chances are you either dont have the little "beeper", or it isn't functioning properly.
TLMNICK
Postby 02slera » Fri Nov 13, 2009 7:47 am
yea my beeper doesn't beep. assuming its even there; i bought the car used a few months ago. any ideas on location of keyless entry beeper? if anyone will hit their button and tell me where the beep comes from id really appreciate it
2002 Solara SLE v6
02slera
Postby 02slera » Sat Nov 14, 2009 10:16 am
bump PLEASE SOMEONE TELL ME WHERE THE BEEP COMES FROM i know alot of you guys are mechanics... whats up with this keyless entry?
2002 Solara SLE v6
02slera
Postby GreenSolara01 » Sun Nov 15, 2009 5:10 pm
What does your key fob look like?
GreenSolara01
Postby GreenSolara01 » Sun Nov 15, 2009 5:23 pm
GreenSolara01
Postby wkbrdr91 » Sun Nov 15, 2009 5:28 pm
can you make the car honk instead of beep? (if it helps i have that remote on the left)
2006 Solara Sport
wkbrdr91
Postby 02slera » Sun Nov 15, 2009 5:36 pm
my remote is like the one on the right except i have a third button at the bottom to open trunk instead of the toyota emblem. and i'd be happy if it honks or beeps i just want a sound to verify the car is locked, i always have to look and see the lights flash, i'm pretty sure that it is supposed to beep, not honk.
2002 Solara SLE v6
02slera
Postby TLMNICK » Sun Nov 15, 2009 5:49 pm
02slera wrote:bump PLEASE SOMEONE TELL ME WHERE THE BEEP COMES FROM i know alot of you guys are mechanics... whats up with this keyless entry?
The little "beeper" is located inside the passenger fender right by the windshield washer reservoir.
TLMNICK
Postby 02slera » Sun Nov 15, 2009 5:56 pm
^^^^ ah hell yes you are the man! now i can start troubleshooting tomorrow. can't thank you enough man. if anyone else has any more info on the subject please post as i have to figure out why my car won't beep. right now i'm thinking put 12 volts to the beeper and see if it beeps. (or see if its even there for that matter as my car was in an accident passenger side front before i owned it) THANKS AGAIN MAN!
2002 Solara SLE v6
02slera
Postby GreenSolara01 » Sun Nov 15, 2009 6:00 pm
GreenSolara01
Postby GreenSolara01 » Sun Nov 15, 2009 6:03 pm
image from a tacoma but the parts should be simalar. Just on the other side. like TLMNICK said.
GreenSolara01
