SolaraGuy.com • View topic - Car dies after boosting
Postby Omes01SLE » Wed Nov 11, 2009 10:19 am
Hi - looking for some advice as to where to start in diagnosing the problem.
Went to start the car (2001 SLE) and nothing, no juice at all. The car starts when I boost it, but the interior light is flashing on and off, and once I put it in gear, the car dies. Checked the battery and it's fine. Any advice before I have to pay to get it towed to the mechanic?
thx
Omes01SLE
Postby SC V6 » Wed Nov 11, 2009 10:32 am
boosting = supercharger install?
If so, its probably a vacuum leak.. check your vacuum lines and make sure there isn't a leak and that its all connected properly
SC V6
Postby 99BlackSandv6 » Wed Nov 11, 2009 11:17 am
I think you are referring to jump starting your car?
If this is the case, it sounds like maybe something is shorted out with the interior light circuit. I need more info to help you.
Postby Ruski » Wed Nov 11, 2009 12:59 pm
start by checking all fuses
Postby solara90 » Thu Nov 12, 2009 10:49 pm
does it still run after taking the booster pack off the battery without putting it into gear?
02 solara 2az
solara90
Postby Omes01SLE » Fri Nov 13, 2009 9:27 am
No, as soon as I remove the booster cables and either try to put it in gear, or turn on the lights - it dies. I'm thinking it could be the alternator?
Omes01SLE
Postby Gibson99 » Wed Nov 25, 2009 7:23 am
ya, typically if it stalls after removing the jumper cables, it's time for an alternator. it's also possible that your battery is SO dead that your alternator is working overtime trying to charge it, and so it's not providing enough juice to keep the engine running.
dunno what's available in ontario, but many parts stores down here will test alternators and batteries for free. i know autozone has a machine in the store where you can take the alternator off the car (about a 15 minute job) and they can test it in the store.
Gibson99
Postby Omes01SLE » Wed Nov 25, 2009 8:53 pm
thx man, yeah it ended up just being a dead battery. The first shop I took it into for testing must have done it wrong... back on the road now! thx.
Omes01SLE
