SolaraGuy.com • View topic - 2003 Solara with Tag Lights out. Please help
Postby whitesolara1 » Mon Nov 16, 2009 1:28 pm
My buddy has an 03 solara with his tag light out. He has replaced his lights with new ones but they are still not working. We cant locate the fuse in the diagrams? Any suggestions would be great. Thanks so much for your help.
whitesolara1
Postby TLMNICK » Mon Nov 16, 2009 1:29 pm
Check ALL the fuses....As far as I know there isn't a fuse strictly for "plate lights"
TLMNICK
Postby whitesolara1 » Mon Nov 16, 2009 2:12 pm
Thanks for your response. It is strange because everything else seems to be working fine. I am not sure where to even start with the fuses.
whitesolara1
Postby imhappy » Mon Nov 16, 2009 9:31 pm
near ur left knee take off the little pocket thing
imhappy
Postby whitesolara1 » Tue Nov 17, 2009 6:19 am
So is that where the fuse is for the tag? Because there are other fuses under the hood too?
whitesolara1
Postby SleeperSolara » Tue Nov 17, 2009 1:42 pm
The fuse boxes in the engine compartment are mostly for the engine, fuel, ignition, starter, turn signals, headlights and other stuff that deals wit the engine.
The fust box near your left knee somewhat under the dash is for interior lighting and the rear tail lights.
There is a diagram behind the "coin" tray that tells you what fuses go to what.
