SolaraGuy.com • View topic - Fluid Capacities
Fluid Capacities
Fluid Capacities
Postby 02slera » Sat Dec 05, 2009 4:01 am
Checked for 2002 solara fluid capacities, found... just some general info for anyone.
CAPACITIES:
Engine, with filter..........5 quarts [1]
Cooling System, Initial Fill..........9.6 quarts
Antifreeze and Engine Coolant
Automatic Transmission, U241E Initial Fill..........3.7 quarts
Automatic Transmission, A541E Initial Fill..........5 quarts
Automatic Transmission, Total Fill
4 speed A541E..........8.5 quarts
4 speed U241E..........8.7 quarts
Manual Transmission, ..........8.9 pints
Differential, Front..........3.4 pints [2]
[1] After refill check oil level.
[2] Final drive for Automatic transmission only.
TORQUES:
Oil Drain Plug.....33 ft/lbs
Manual Transmission
Fill Plug 36 ft/lbs
Drain Plug 36 ft/lbs
2002 Solara SLE v6
02slera
Postby makethemusic72 » Sun Dec 06, 2009 8:10 pm
thanks man.
2003 Solara 4 Cyl, automatic. Floss as @#$%.
makethemusic72
