SolaraGuy.com • View topic - need help on open door problem!!
Postby thenewguy » Thu Dec 10, 2009 10:41 am
the problem im having is my door isnt closing properly. I close it and its not closing all the way like it should be. and the open door light inside shuts off but turns on if the car goes over and small bumbs or if my arm pushes on the door slightly. im clueless so far.
Thanks
thenewguy
Postby wkbrdr91 » Thu Dec 10, 2009 10:49 am
You sure its a door problem and not an electrical problem??
2006 Solara Sport
wkbrdr91
Postby thenewguy » Thu Dec 10, 2009 11:09 am
yea its a door problem. you can see from the side view of the car that the door looks like its not closed all the way. but i cant find whats preventing it from closing.
thenewguy
Postby Ruski » Thu Dec 10, 2009 11:13 am
check trim pieces, check the bolts holding the door to the cars frame, it may also be the hing going from the car to the door thats out of whack.
Postby yota » Thu Dec 10, 2009 11:23 am
I had this problem with my passenger door in the cold. WD-40 and then ultimately a hair dryer to warm up the hinge were how I got it closed properly.
yota
Postby thenewguy » Thu Dec 10, 2009 4:07 pm
ok ill try the hinges too i tightened the latch on the car a little but no deal. :(
ill keep you guys updated. thanks
thenewguy
Postby nemoxfishy » Sun Dec 13, 2009 5:52 pm
Might be your window hitting against the black trim piece.
Try lowering your window and closing the door.
nemoxfishy
