SolaraGuy.com • View topic - Cylinder 3 misfiring: problem: PO303
Postby thenewguy » Thu Dec 10, 2009 4:18 pm
the 3rd cylinder is misfiring in the engine and im getting an engine check light. causing the whole car to shake. i've started off installing the spark plugs(front 3 are done already and need to do back three now.. :-? ) i've also put in fuel injector cleaner in my gas tank. Any other suggestions of what else it might be?
lol it seems like its one problem after another....ughh :drinking: lol
Thanks
thenewguy
Postby thenewguy » Thu Dec 10, 2009 4:53 pm
oh yea also, whats the firing pattern for our cars? which is the 3rd cylinder
Thanks once again :bday:
thenewguy
Postby Midias » Thu Dec 10, 2009 5:38 pm
I had a bad wire cause the problem. Got a new set of NGK wires from advance auto for a good price.
Postby Eye8Pussies » Thu Dec 10, 2009 5:42 pm
3 is the middle one near the firewall
Postby thenewguy » Thu Dec 10, 2009 6:55 pm
so i checked out the wires at ngk.com..
if it comes to that would i only need 1? or 2 for all 6 plugs?
thenewguy
Postby thenewguy » Thu Dec 10, 2009 6:56 pm
oh one more thing.. im having trouble in taking the back three plugs out. the space is so confined back there. :evil:
there a certain way to pull those back 3 out? or do u just have to muscle them out.
thenewguy
Postby 1gSE » Thu Dec 10, 2009 7:27 pm
3 plug wires. If you can reach back there and pull them off...you should be able to get the plugs out
Solara-M62 @ 5.5psi
1gSE
Postby Midias » Thu Dec 10, 2009 8:21 pm
thenewguy wrote:so i checked out the wires at ngk.com..
One NGK set comes with all 3 needed wires
Postby thenewguy » Thu Dec 10, 2009 10:53 pm
whats the firing pattern for the gen1 solaras?
thenewguy
Postby thenewguy » Thu Dec 10, 2009 10:54 pm
diagram would be great :bday:
thanks
thenewguy
Postby SleeperSolara » Thu Dec 10, 2009 10:58 pm
Try a Hayne's repair manual.
Postby thenewguy » Thu Dec 10, 2009 11:02 pm
ehh i need it to know it now atm cuz this car is my daily driver and i gotta work tommorow. cant buy it too saving $$. :cry:
thanks though
thenewguy
Postby Eye8Pussies » Thu Dec 10, 2009 11:40 pm
Firing pattern:
Firewall
1 3 6
2 4 5
Rad
Postby thenewguy » Fri Dec 11, 2009 12:01 am
im gonna sound like a idiot right now because this was my very first time doing this and i mixed up the the wires for the three rear cylinders. :drinking: :drinking:
the front three are in the correct order but the back 3 are mixed up.
which end goes to what? diagram please :bday: diagram would be AWESOME
[1][3][5]
}where do wires 2,4,and 6 go to? thanks again :D :D
[2][4][6]
thenewguy
Postby dudutzu » Fri Dec 11, 2009 2:01 pm
on my car the wires going from front bank have numbers on them "1". "3" and "5" and I assume thats where they go, but since you have them all messed up I'll go take a quick look for you
dudutzu
Users browsing this forum: No registered users and 64 guests
