SolaraGuy.com • View topic - Clutch friction point
Postby mazen222 » Sun Dec 13, 2009 12:30 pm
After changing my clutch, the friction point was very low... as soon as i start releasing the clutch engages. I thought i could change the friction point by playing with the pedal height. My mechanic told me it wont change anything, but i thought i had nothing to loose, so i went under the dash and played with the bolt and nut above the clutch pedal and reduced the height of it.
This made things worst, i couldnt even put the shifter in first gear anymore... so i re-adjusted the height back to its original point.
Now the car drives fine, but the friction point is still very low. but what confuses me is that sometimes, for no apperant reason, the friction point changes to almost mid level of the clutch pedal height and the clutch feels like there is a good spring pushing it upwards all the time.
I don't know if i just confused everyone here, but if anyone can guide me in the right direction to fix this, it would be very appreciated.
Thanks!
1999, 5 Speed V6
mazen222
Postby mazen222 » Mon Dec 14, 2009 8:09 am
Anyone?
1999, 5 Speed V6
mazen222
Postby jetbtkng » Mon Dec 14, 2009 12:28 pm
thats how they are, as it wears out the peddle will move farther out................... :drinking:
Postby mazen222 » Thu Dec 17, 2009 7:08 pm
no... the clutch is brand new.
on one start it will be super low and some other times it will be super high and with good resistance. next start it will be low again
1999, 5 Speed V6
mazen222
Postby jetbtkng » Thu Dec 17, 2009 7:23 pm
check the resivour, it my be low, as it is hydralic, also may need to bleed it................... :drinking:
Postby solara90 » Thu Dec 17, 2009 10:36 pm
X2
jetbtkng wrote:check the resivour, it my be low, as it is hydralic, also may need to bleed it................... :drinking:
02 solara 2az
solara90
Postby mazen222 » Fri Dec 18, 2009 5:01 pm
the oil level is just above the lowest point, i will fill it up and bleed it.
is it easy to bleed this myself? or should i just not waist my time and ask a mech?
1999, 5 Speed V6
mazen222
Postby System_Crash » Sat Dec 19, 2009 8:40 am
Sounds like air in the system or hydro booster (or what ever they have) may be going out.
You'll need 2 people to bleed any system. 1 to pump the clutch and hold down while the other bleeds. (and probly gets a bath)
Pearl White 2004 Solara V6 90,000 miles
System_Crash
Postby Eye8Pussies » Sat Dec 19, 2009 10:37 am
... Or you can use a one man bleed kit.
But it doesn't sound like thee is air in the system if the feel is inconsistent. Sounds like there may be a bad seal in either the slave or master cylinder
Users browsing this forum: No registered users and 64 guests
