SolaraGuy.com • View topic - Timing belt tensioner
Postby hari-bhari » Wed Dec 16, 2009 12:55 pm
Is it necessary to replace the timing belt tensioner along with the timing belt and water pump? I've got varying reports from my mechanics
hari-bhari
Postby akora12 » Wed Dec 16, 2009 1:28 pm
As long as the seal and rod are within specs, it's fine to reuse.
Postby Eye8Pussies » Wed Dec 16, 2009 1:29 pm
if it's not leaking, then no.
but if you can find it cheap somewhere or have a spare one handy, then you may as well replace it as well.
otherwise though, no.
Postby hari-bhari » Wed Dec 16, 2009 1:39 pm
thAnks. Quoted $500 for belt, pump, and all seals. Incl parts and labor. Sound right?
Anything else I should get done at 90k? Plugs were replaced at 60k, guess I should get trans fluid changed as well (MT)
hari-bhari
Postby that1mexguy » Wed Dec 16, 2009 2:54 pm
$500 sounds about right man
that1mexguy
