SolaraGuy.com • View topic - shaving off emblems
shaving off emblems
shaving off emblems
Postby newjoe » Sun Dec 20, 2009 12:45 pm
whats the best and easiest way to take off the emblems on the back of the car? thanks. -joe
Every man dies, not every man lives.
2002 Solara SE I4
newjoe
Postby ThatVietGuy » Sun Dec 20, 2009 12:58 pm
ThatVietGuy
Postby newjoe » Sun Dec 20, 2009 4:32 pm
thanks.
2002 Solara SE I4
newjoe
Postby sahuddleston » Sun Dec 20, 2009 7:28 pm
heat gun and fishing line or floss. be careful!
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby 02slera » Sun Dec 20, 2009 7:37 pm
oh wow i been wanting to take a couple off, thought for sure it would leave holes where it was attached. never bothered to search for it. this is sweet.
2002 Solara SLE v6
02slera
Postby LEE337 » Mon Dec 21, 2009 10:56 am
sahuddleston wrote:heat gun and fishing line or floss. be careful!
NOOOOOOOO!!!!!! :o
DO NOT USE A HEAT GUN!!!!
Use a hair dryer.
If you use a heat gun you will fuk up the paint royally!
I almost made that same mistake.
Lucky for me I had my fellow SGers telling me not to use a heat gun! :D
I repeat:
Use a hair dryer.
Postby Chinky420 » Mon Dec 21, 2009 11:10 am
....dynamite works good....
....so does a sledgehammer....
....just don't expect your car to run exactly the same afterwards
j/k
for me i used goo gone and fishing line. heat helps (i did mine in the summer in texas, so no heat-gun/hairdryer for me, the sun worked well enough)
there'll be some residual adhesive stuck on the body...just use your finger to roll it into a ball and to roll it off the car.
Chinky420
Postby dkertis10 » Mon Dec 21, 2009 3:39 pm
i just used a hair dryer on the emblem for a minute, used fishing line to take it off, then some scratch remover stuff to get off the crap it left behind. elbow grease is required for it
Kicker sound system, 17 inch MB Wheels on Continental ContiExtremeContact tires, more mods to come..
dkertis10
Postby unbalancedwood » Mon Dec 21, 2009 4:13 pm
Just for further reference to the discussion.
I used 'WAX FLOSS", its softer, I broke numerous strands but it didn't scratch at all. I took off all emblems & then used some goo gone to remove the remaining sticky substance. Then washed the car (mainly getting the goo gone off).
I still have the emblems...hoping to put the 2 V6 ones on the MR2 one day ;)
unbalancedwood
Postby newjoe » Tue Dec 22, 2009 6:49 pm
so i removed them, and there's a little shadow where the emblem used to be. does it eventually fade over time?
2002 Solara SE I4
newjoe
Postby ThatVietGuy » Tue Dec 22, 2009 8:12 pm
Yes, consider it like a tan.
ThatVietGuy
Postby makethemusic72 » Wed Dec 30, 2009 11:10 am
I had some paint tan lines, they went away after i used some scratch remover and paint cleaner for some reason.
2003 Solara 4 Cyl, automatic. Floss as @#$%.
makethemusic72
Postby 02slera » Wed Dec 30, 2009 6:46 pm
My emblems are now gone from the rear of the car, looks much cleaner, i also have the slight "shadow" or "tan line" where the emblems were, ill have to try some scratch remover and paint cleaner and hopefully it works for me as well.
Just for general info... to get mine off i used a hair dryer to heat up emblem, fishing line to "floss" behind the emblem, and then most of the left over glue i simply rolled off with my finger, and what glue was left i used bug and tar remover (made by turtle wax) and it worked very well, (i had also tried goo gone but the bug and tar remover worked much better) now i just have the very slight shadow of the emblem left as mentioned above, its very hard to see though.
2002 Solara SLE v6
02slera
Postby kenny6683 » Wed Dec 30, 2009 8:16 pm
the tan or "shadow" will most likely not come off..i think maybe if you get the trunk buffed it might though
kenny6683
Postby 99BlackSandv6 » Wed Dec 30, 2009 8:35 pm
Yup, it'll buff out. :wink: :up:
