SolaraGuy.com • View topic - 2002 lara spoiler removal.
Postby sinnsation » Wed Dec 23, 2009 4:07 pm
Hello,
I have been looking over this forum for awhile now and just now registered. I love the site. It has helped me quite a few times.
I know this has been discussed before but didn't find the answer on how to remove the spoiler on an 02 solara. I have removed the lining from inside the truck but I have no access to the spoiler from there.
The reason being, is that one of the studs has broke and I would like to take the spoiler off so I can try and repair it.
Thank you
sinnsation
Postby ThatVietGuy » Wed Dec 23, 2009 4:23 pm
The stud that holds the spoiler to the trunk?
I would assume that makes it easier to take the spoiler off :-?
ThatVietGuy
Postby sinnsation » Wed Dec 23, 2009 4:28 pm
I assume so. The right side is not held on so the spoiler is lifted off of the trunk slightly. I can pull up on it and see a hole in the trunk. Since I can't get to the spoiler from inside the trunk Im really not sure how the spoiler is held on.
I assumed it was a couple of bolts/nuts to hold it down.
sinnsation
Postby ThatVietGuy » Wed Dec 23, 2009 4:39 pm
If you've pulled off the trunk lid lining, you should see four (in your case three) bolts, I believe, under the spoiler.
ThatVietGuy
Postby 99BlackSandv6 » Wed Dec 23, 2009 5:09 pm
Yes, there are bolts that hold it on and it slides off of the studs.
Postby sinnsation » Wed Dec 23, 2009 7:08 pm
Ok. I'll take another look. I probably overlooked them.
Thanks guys.
sinnsation
Postby 99BlackSandv6 » Wed Dec 23, 2009 8:47 pm
They're not plainly visible, you have to look through the frame of the lid but they are there. I believe I had to use an extension and a 12mm socket for them, but don't quote me on the size.
Postby sinnsation » Fri Dec 25, 2009 11:11 am
Alright. Thanks to you guys I was able to remove the spoiler.
I found that one of the rivets that the spoiler slides onto was gone which is why it was lifted on one side.
This is probably a dumb question, but does anyone know where I could get a replacement? I wnet to Toyota but they want to charge me for a new spoiler which doesn't make sense.
sinnsation
Postby sahuddleston » Fri Dec 25, 2009 7:13 pm
Pm reggie, he is a parts guy and may have a solution for you.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby 99BlackSandv6 » Sun Dec 27, 2009 1:27 am
Yeah, I have no idea where to get those unless Reggie can hook you up. Mine are f'ed up too BTW, it's probably common. The spoiler was a pain to fit back on correctly but it looks good and feel solid. Maybe you should just try harder. :lol:
