SolaraGuy.com • View topic - My car has been shutting off
Postby SpeedySolara » Wed Dec 30, 2009 4:06 pm
Maybe you guys could give me some insight and/or solutions to fix my issue. My car has been shutting off on me for the past 3 months (approximately) every so often. It usually happens after a hard run once I come to a stop. It starts by reving low and ultimately shuts off unless I rev it up to avoid it from turning off. I thought it was my clutch and/or needing a tune but after both have been done this problem still persists. Again, it happens every so often for the past few months so its not something that happens every single time I'm stopped but it is a concern. Any ideas?
SpeedySolara
Postby Eye8Pussies » Wed Dec 30, 2009 4:24 pm
it's your iac- clean and/or adjust it as necessary!
Postby Dawgz » Wed Dec 30, 2009 4:25 pm
low end fuel issue.
Postby sahuddleston » Wed Dec 30, 2009 7:11 pm
clean out your throttle body and if it persists it sounds like a fuel pump/line issue.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby WUTANGCLAN » Wed Dec 30, 2009 10:00 pm
^x2
WUTANGCLAN
Postby ASG14 » Wed Dec 30, 2009 10:02 pm
Tlaked to Dawgz, we think it's the plugs.
ASG14
Postby jetbtkng » Wed Dec 30, 2009 10:16 pm
its the idle control thingy.................. :drinking:
Postby SleeperSolara » Wed Dec 30, 2009 11:07 pm
I have the same problem.
I think it's the idle control valve.
Postby Dawgz » Thu Dec 31, 2009 4:20 am
We could still look at the IAC as King suggested, but with plugs that have 20k on them and just went thru a day or so with Supra injectors (no tune) and then a dyno tune, those spark plugs need replacement. (I had a talk with speedy about this as well).
either way, we will get to the bottom of this! lol, cya at adam's.
Postby Eye8Pussies » Thu Dec 31, 2009 11:01 am
Doubt it's the plugs still. They won't foul that easily. I'm still on the same set since I got boost, and my car's been through he'll and back tune-wise.
Also, of it was spark or fuel related, there would be serious misfires at high rpms as well.
The fact that he says the car stumbles and then dies after hard runs meanthat the iac is responding slowly due to heat and the extra load from the blower is causing the car to stall as the iac can't respond fast enough. Clean it or replace it (worse case) and of should be fine
Postby jetbtkng » Thu Dec 31, 2009 12:04 pm
ive had the same issue with my 2000 lara twice, i just cleaned with throttle body cleaner, then wd-40'ed it, now works fine, no dying at idle, thats all it is, its a common problem, it gets dirty................... :drinking:
Postby mazen222 » Thu Dec 31, 2009 3:01 pm
I have the same problem. Only happens after i drive hard on the car. I think its the thotle thingy that need cleaning
1999, 5 Speed V6
mazen222
