SolaraGuy.com • View topic - brake fluid
brake fluid
brake fluid
Postby pro956 » Fri Aug 01, 2003 12:20 pm
i was checking my fluid levels today and :o
my brake fluid had a bit of black fluid floating up top (like oil floating on water)
any idea what it could be?
what should i do about it?
thanks
AIM: pro956
2002 5-speed se v6
pro956
Postby pro956 » Fri Aug 01, 2003 7:10 pm
pro956 wrote:i was checking my fluid levels today and :o
or maybe that's my clutch fluid :-?
it's in the far (nearest to the windshield) right corner, i think maybe the break fluid is right infront of it
AIM: pro956
2002 5-speed se v6
pro956
Postby impactX » Sat Aug 02, 2003 1:36 am
Brake fluid cap should be closed so nothing can flow inside... I suggest you use a suction pump to get the black stuff out.
impactX
Postby DavPak » Sat Aug 02, 2003 3:35 am
pro956 wrote:or maybe that's my clutch fluid :-?
toyota made it easy on us, all reservoirs are labeled! read the cap, it'll tell you what it is.
'02 Solara S/C'ed V6 5-spd
DavPak
