SolaraGuy.com • View topic - Divers window screeeeeeches everytime it is rolled down
Postby SolaraMan7890 » Thu Jan 07, 2010 5:33 pm
...nuff said...
it's embarrassing. Help please!
Problem only when it is being rolled DOWN, rolling up is silent.
Passenger window is fine.
2000 SE.
SolaraMan7890
Postby D-money » Thu Jan 07, 2010 7:42 pm
your gonna have to pull the door apart but its not to hard i think there are only about five screws
D-money
Postby SleeperSolara » Thu Jan 07, 2010 9:57 pm
Mine does that too when it turned cold.....
Haven't had time and the cold weather isn't helpin'..... :-?
Postby SolaraMan7890 » Thu Jan 07, 2010 10:26 pm
Any ideas why it's doing this? it seems as though it only does it when it turns cold...
2000 SE.
SolaraMan7890
Postby SleeperSolara » Thu Jan 07, 2010 11:17 pm
SolaraMan7890 wrote:Any ideas why it's doing this? it seems as though it only does it when it turns cold...
Not sure.
It just started wit my car.
Postby anttarz » Fri Jan 08, 2010 8:53 am
You're gonna have to remove the door panel and tighten & clean the window bolts & guides.
Removing the door panel will be the most difficult part of it; specifically removing the doorhandle housing. Be careful and try not to break any clips.
anttarz
Postby SolaraMan7890 » Fri Jan 08, 2010 8:56 am
would spraying silicon in the crack work?
2000 SE.
SolaraMan7890
Postby kenny6683 » Fri Jan 08, 2010 2:25 pm
maybe all you need to do is grease the window regulator...sometimes they dry up after few years.
what do you mean by spraying silicon in the crack???? PAUSE!!!!
dont do anything to the crack lol
kenny6683
Postby SolaraMan7890 » Fri Jan 08, 2010 10:00 pm
kenny6683 wrote:maybe all you need to do is grease the window regulator...sometimes they dry up after few years.
hahahaha, where would you apply the grease?
2000 SE.
SolaraMan7890
Postby dug320 » Sat Jan 09, 2010 1:25 pm
Try and figure out where the sound is coming from.
Sometimes dirt can get into the channels on the sides. With the window down and clean all three channels with a brush and then spray a bit of silicone spray into the side channels to see if it makes a difference.
If that does not work the panel has to come off.
dug320
