SolaraGuy.com • View topic - Off throttle problem*
Postby dudutzu » Sun Jan 10, 2010 8:51 am
I searched but I couldn't find anything related to my situation
So I drive a 99 SE V6 MT with a little over 120k miles
everytime when I go off throttle, in any gear(in higher gears doesn't feel as bad but is there), for a split of second the car accelerates like someone is pushing the gas and then cuts off, and that doesn't matter how slowly/smooth I back off, and is very annoying, the first time when noticed it actually scared me
I don't know when it started to do this cuz I got the car only few months ago, and was doing it since
and there is no CEL on or anything
the car appears to idle at a normal speed around 700rpms
what can it be and what to do to fix it?
thanks in advance guys :wink:
dudutzu
Postby solara90 » Sun Jan 10, 2010 10:59 am
i might be wrong but i think it has something to do with the throttle position sensor delay? correct me if i am wrong?
02 solara 2az
solara90
Postby MisterTedster » Sun Jan 10, 2010 2:01 pm
Did you recently do any engine mods? i.e. sri, bored tb, etc?
02 SE V6
MisterTedster
Postby dudutzu » Sun Jan 10, 2010 2:50 pm
MisterTedster wrote:Did you recently do any engine mods? i.e. sri, bored tb, etc?
no
only thing I've done is this: forgot how you call it
but was doing it before that also
dudutzu
Postby 99BlackSandv6 » Sun Jan 10, 2010 4:05 pm
Sounds like fuel delivery problem, most likely caused by the TPS (throttle position sensor) have a shop check it out for you.
Postby dudutzu » Mon Jan 11, 2010 6:54 pm
anyone else has other ideas?
dudutzu
Postby jetbtkng » Mon Jan 11, 2010 7:13 pm
TPS (throttle position sensor, i bet thats your problem, its just a plastic piece of >>I'm a douche<<, i replaced one already, although i did get a cell with it, but only when it totally failed, i bet its worn out.............. :drinking:
Postby dudutzu » Mon Jan 11, 2010 7:36 pm
jetbtkng wrote:TPS (throttle position sensor, i bet thats your problem, its just a plastic piece of >>I'm a douche<<, i replaced one already, although i did get a cell with it, but only when it totally failed, i bet its worn out.............. :drinking:
to say that the TPS is faulty, but if the CEL isn't ON(at least for now) does that mean that if I check it with a multimeter gonna get that the TPS is in limits? cuz if it wasn't(within limits) the CEL would be ON, right?
dudutzu
Postby jetbtkng » Mon Jan 11, 2010 7:44 pm
all it is, remember slot cars, well its just like the controller that makes the slot car go faster or slower, wires in a line wrapped on an insulator, and a metal arm going up & down rubbing against them, after time it gets worn & starts sticking............... :drinking:
Postby solara90 » Tue Jan 12, 2010 10:49 am
^ yeah they will usually get a dead spot in them from the usual 1/2 throttle or less which you usually use during normal driving.
You can easily test a TPS with an oscilloscope
i.e. look at the diagram here
http://www.aa1car.com/library/tps_waveform.gif
02 solara 2az
solara90
Postby Chinky420 » Tue Jan 12, 2010 11:10 am
about how much does a new tps cost anyway?
Chinky420
Postby solara90 » Tue Jan 12, 2010 12:55 pm
you 1mz guys are lucky your can be replaced seperately and there about $60
http://www.autopartswarehouse.com/searc ... or&submit=
the 2az guys have to buy a whole new throttle body which is about $800 because toyota had some great idea to incorporate everything into the throttle body!
02 solara 2az
solara90
Postby dudutzu » Tue Jan 12, 2010 6:45 pm
solara90 wrote:^ yeah they will usually get a dead spot in them from the usual 1/2 throttle or less which you usually use during normal driving.
thanx
that would make sense
what if I don't have access to a oscilloscope, is any other way to test it to get the same result?
dudutzu
Postby dudutzu » Tue Jan 12, 2010 6:46 pm
Chinky420 wrote:about how much does a new tps cost anyway?
I want to find the problem first and then start replacing parts, not the other way
dudutzu
Postby solara90 » Tue Jan 12, 2010 10:09 pm
Yes, i could explain it in my own words but ill just use the copy and paste method!
1) Test the TPS for signal voltage to the computer. Insert a pin through the ground wire and another pin through the signal voltage wire and connect the voltmeter probes to the pins using alligator clips. Start the engine. As you manually open and close the throttle plate, watch the voltage readings at the meter. The voltage should gradually increase from 1 to 5 volts and back to 1 volt. If you see an erratic or no movement of voltage signal, replace the TPS sensor.
2) Test the TPS sensor’s resistance. This is an alternate method to test TPS sensors equipped with a variable resistor. Unplug the TPS electrical connection. Set your multimeter to ohms. Connect the ohmmeter probes to the sensor’s supply and signal wire contacts. Manually open and close the throttle plate and watch the resistance reading at the meter. The resistance should gradually increase and decrease as you open and close the throttle plate. If there is an erratic resistance change, no change, or no resistance at all, replace the TPS.
02 solara 2az
solara90
