SolaraGuy.com • View topic - maintenance list...
maintenance list...
maintenance list...
Postby solara90 » Wed Feb 03, 2010 8:13 pm
So, once winter is finally done i want to do some preventative stuff on my car. I have about 103K on her right now...
What is on my list so far
- TRD RSB
- Water pump/ serp. belt (possible replace tensioner depending on condition)
- ^ Coolant flush
- New rotors/ pads
- new struts/ mounts/springs
Thats all i can think of right now. One question I have is about the timing chain. I see they talk about replacement of it on the V6, but i dont see anything about it on the 2.4 in my chilton manual.
You have any other things i should look at.
02 solara 2az
solara90
Postby 99BlackSandv6 » Wed Feb 03, 2010 9:29 pm
Chilton manuals aren't that great. Especially if they tell you to change the timing chain on a 1MZ. Belts baby, belts!!!
Check your Power-steering fluid and Trans fluid, and of course your brake fluid. They always get left out for some reason. Also how about an oil change. Don't forget that. Top off the washer fluid too. :D
Postby Ruski » Wed Feb 03, 2010 9:33 pm
rotate tires, lubricate moving parts( RSB, Door hinges ect)
Postby solara90 » Thu Feb 04, 2010 5:23 am
Did a transmission flush July 09, and i put in a new master cylinder/ booster May 09. So I'll check the power steering fluid
99BlackSandv6 wrote:Chilton manuals aren't that great. Especially if they tell you to change the timing chain on a 1MZ. Belts baby, belts!!!
02 solara 2az
solara90
Postby 99BlackSandv6 » Thu Feb 04, 2010 11:00 am
Nice! So I guess the trans fluid and brake fluid are still good and fresh. :sweet:
Postby frohboy33 » Wed Feb 10, 2010 12:21 pm
Your 2AZ-FE does not have a belt. It has a chain. Chains don't need to be replaced. Only the v6 has the belt, and that should be changed at 90,000. I have the 03 I4, no mention of any timing maintenance in my toyota manual.
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
