SolaraGuy.com • View topic - Pulling the Engine
Pulling the Engine
Pulling the Engine
Postby TxBmbleBee » Wed Feb 10, 2010 8:07 pm
I searched and found no posts on directions for pulling the engine. I guess if I need directions I probably shouldn't do it?
All I could find was a post that King made saying to leave the a/c unit in the bay. My question is for those who have actually pulled the engine themselves, not people who have had others do it for them. Any basic steps or helpful advice or should I just buy a hanes manual and not waste board space? :lol:
"i just wanna go fast..."
TxBmbleBee
Postby bbq bob » Wed Feb 10, 2010 8:09 pm
check with gregtrd. he does this on a regular basis.
bbq bob
Postby SleeperSolara » Wed Feb 10, 2010 11:11 pm
You can leave the A/C unit in the car hangin' somewhere, but not to kink up the lines.
Then you can unbolt the whole front subframe, and the fuel connections and engine harness plugs, and pull the engine from below.
I think that's the easiest.
That's what i'll be doin' when i do and get my motor swap done.
Postby akora12 » Thu Feb 11, 2010 6:34 am
I definitely suggest getting a manual to make things easy.
You can easily pull the motor from the top w/o touching the subframe (aside form the mounts).
Postby JMSinMaryland » Thu Feb 11, 2010 7:11 am
You definitely want to disconnect the battery.
JMSinMaryland
Postby Mole » Thu Feb 11, 2010 11:06 am
^ open the hood too!
Postby solara90 » Thu Feb 11, 2010 12:01 pm
just keep taking bolts out, it should come out eventually
02 solara 2az
solara90
Postby Eye8Pussies » Thu Feb 11, 2010 12:49 pm
SleeperSolara wrote:You can leave the A/C unit in the car hangin' somewhere, but not to kink up the lines.
no, it's a alot easier to do it through the top
another thing that makes things a lot easier- pull the engine harness out through the wirewall (disconnect on the ecu side)
also, lift the motor up about a foot off the subframe (make sure hte lines don't kink), then just hit up the banjo bolt for the p/s hose with an impact gun. Make sure that you don't accidentally unbolt the secondary nut (it's hard to explain, but when you fiddle around with it, it becomes pretty clear) that is directly attached to the pump though, otherwise you will get quite a leak from there when you reattach everything. Install is reverse of removal. Be very careful that you don't strip the threads on the banjo bolt.
Postby SleeperSolara » Thu Feb 11, 2010 1:49 pm
Really??
I thought it would be easier to take it from the bottom....
Postby Eye8Pussies » Thu Feb 11, 2010 9:07 pm
not at all....maybe if you have a lift and you're only taking out the tranny, but not if you're doing both.
and definitely not on your driveway
Postby SleeperSolara » Thu Feb 11, 2010 10:12 pm
Eye8Pussies wrote:not at all....maybe if you have a lift and you're only taking out the tranny, but not if you're doing both.
I see.
Hmm.....
