SolaraGuy.com • View topic - 1MZ- fe weight?
1MZ- fe weight?
1MZ- fe weight?
Postby Twin Turbo » Tue Feb 23, 2010 10:08 pm
Can anyone tell me how much our beloved 1mzfe weighs?
Follow @ballsofthunder for non-stop ridiculous action
Twin Turbo
Postby 02slera » Wed Feb 24, 2010 7:21 pm
a little over 3200 pounds i think, unless your convertible, then its well over 3400.
i went to autotrader website and it said under specs.
3230 or 3472 conv.
im assuming your talking about the car and not the engine alone, the engine alone i have no idea.
2002 Solara SLE v6
02slera
Postby Twin Turbo » Wed Feb 24, 2010 7:58 pm
Thanks but i am curious about the weight of just the engine itself. I cant seem to find it online anywhere
http://www.facebook.com/album.php?aid=3 ... 67a079d37c
Twin Turbo
Postby Eye8Pussies » Wed Feb 24, 2010 9:37 pm
you want an estimate? or an exact number?
I would guess it to be around 300 or so, because it's heavy enough that you can't pick it up even with 2 people, but when it's sitting on a tire, you can pretty easily rock it and lift up one side of it when needed
Postby Twin Turbo » Fri Feb 26, 2010 4:23 pm
Thanks bro. Thats all i needed was a good estimate. Thats a hell of a Camry you have there dood. Ill bet that machine has kicked the crap out of a few V8's that Camrys have no business kicking the crap out of!
Twin Turbo
Postby 99BlackSandv6 » Sat Feb 27, 2010 1:56 am
Eye8Pussies wrote:I would guess it to be around 300 or so, because it's heavy enough that you can't pick it up even with 2 people,
Wait, two guys can't pick up 300lbs? Or is this an estimate in Kg. You're Canadian, so I'm guessing kg. Just for clarification. :wink:
Postby EEngineer » Tue Mar 02, 2010 3:37 pm
1MZ is around 400 lbs.
3VZ is around 470 lbs
2GR is around 360 lbs
IIRC
94 Camry 3VZ 5 spd swapped - parted out 2009
92 ES300 3VZ 5 spd supercharged @ 300.8whp
99 Solara 1MZ 5 spd bone stock (not for long)
EEngineer
Postby Eye8Pussies » Tue Mar 02, 2010 5:32 pm
yeah, actually, I think eengineer might be closer as an estimate.
I was going to rethink and say it's probably closer to 350, but 400 I'd personally say less than 400 though, only because it's not too hard to move in terms of lifting one side of it, etc.
Postby DriDed » Tue Mar 02, 2010 5:36 pm
I didn't know the 1mz is that heavy of an engine, I read somewhere that the LS1 is around the same weight.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby ozone » Tue Apr 06, 2010 3:07 pm
I'm surprised so many of you answered without asking the "obvious" question, which is:
What do you mean by 1mzfe? Does it include the transmission too? The alternator, the starter motor, A/C, what? I am in the middle of transplanting this motor into my Corolla, so I want to know what everything under the hood weighs, not just the block and heads and manifolds.
Unfortunately, I don't know the answer either exactly. I made a balance beam scale and weighed my 4age and 4agze motors and when the engine comes out of the Solara, I plan to weigh it the same way, but I am still a few weeks away from removing the Solara engine. If anyone is interested, they should keep an eye on my website: www.ozone1000.com.
I can tell you that the E58 transmission in my Corolla which is very similar to the one in the Solara weighs 110 lbs. My expectation is that the E153 weighs about the same. From searching online, I have found numbers of about 400 lbs for the 1mzfe, but just like here, no one mentioned what was included in that weight.
ozone
Postby 99BlackSandv6 » Tue Apr 06, 2010 4:58 pm
Hey ozone, I just checked out your site. I thought it was pretty cool. Just wanted to let you know. :sweet:
Postby ozone » Tue Apr 06, 2010 5:22 pm
Thanks. I just like to help people on the web, like they've helped me.
ozone
Postby akora12 » Tue Apr 06, 2010 7:01 pm
Ozone's estimate of the E153's weight is right. I was able to pick it up and move it by myself.
Postby 99BlackSandv6 » Tue Apr 06, 2010 8:47 pm
It's pretty stupid that the factory Solara muffler weighs 21lbs.
I weighed mine way back when I took it off and thought the
scale must have been wrong. I didn't realize the 5speed box
was that light. Some good info here.
Postby ozone » Wed Apr 14, 2010 3:21 pm
Well, I finally have an answer to the question. I removed the engine from my donor Solara Monday and I just now weighed the engine.
The configuration was:
Engine
Transmission
Alternator
Starter
AC compressor
Power steering pump
Intake and exhaust manifolds + a portion of the exhaust ending behind the flex pipe (flex pipe included).
Two front motor mounts
Wiring (except ECU)
Basically everything under the hood that attaches to the engine except the drive shafts.
The weight was (drum roll please) ~522 lbs
Assuming the transmission weighs ~110 lbs (based on the E58), the engine and all its ancillaries would weigh: ~412 lbs.
Enjoy!
ozone
