SolaraGuy.com • View topic - Stock 16" wheel weight?
Postby SirThomas8 » Fri Feb 26, 2010 8:43 pm
Anyone know what the wheel weight is for the stock 16" wheels on the Solara Gen 1? Without the tires.
SirThomas8
Postby ThatVietGuy » Fri Feb 26, 2010 9:00 pm
ThatVietGuy
Postby 99BlackSandv6 » Sat Feb 27, 2010 2:01 am
With tires I think mine were right at 44lbs. Estimation of the tire weight would be about 23-27. So I'm guessing about 17-19 lbs.
Postby SirThomas8 » Sat Feb 27, 2010 2:09 am
Cool, thanks man. I tried doing a search but I guess I was putting in crappy keywords.
So in that thread it's estimated at between 37 - 44 lbs. Which means the wheel alone is between 12lbs to 24lbs (given a 16" tire on tirerack.com is usually between 21 - 25 lbs).
Which...unfortunately doesn't tell me much lol.. Most wheels are between 12lbs and 24 lbs.. But I highly doubt the wheel is under 15 lbs.
The stock 15" Camry steelies I had were just around 20lbs each.
I'm gonna make a guess and say the 16" wheel is close to 22 lbs.
SirThomas8
Postby 99BlackSandv6 » Sat Feb 27, 2010 2:26 am
I would bet it's very close to 19lbs.
Postby SirThomas8 » Sat Feb 27, 2010 3:18 am
99BlackSandv6 wrote:I would bet it's very close to 19lbs.
Yeah that's probably more accurate. Thanks.
SirThomas8
Postby ThatVietGuy » Sat Feb 27, 2010 3:20 am
20.1 on my bathroom scale.
ThatVietGuy
Postby SirThomas8 » Sat Feb 27, 2010 3:36 am
Awesome! Thanks for weighing your wheel dude! The mystery is solved.
So the 16" stock Solara wheel weighs about the same as the 15" steelies... interesting.
SirThomas8
Postby 99BlackSandv6 » Sat Feb 27, 2010 12:06 pm
20.1
Well, I was pretty close. Thanks for the info VIetGuy.
