SolaraGuy.com • View topic - 12mpg... HELP!
12mpg... HELP!
12mpg... HELP!
Postby treefrog99 » Sun Mar 14, 2010 5:31 pm
Hey again everyone..
Well the title says it all. I am getting about 12-14mpg on the highway at best!!!!! Worse in town, of course.. probably around 10-11mpg in town.
I am driving a 1999 V6 Solara, Automatic.. car has 241,000Kms on it (yes, Kilometers*, I am in Canada)
When I bought the car, the EGR valve was gone, replaced that. Also, there was a few leaks in the exhaust were the piping connected, that was fixed. Also has a brand new air filter. And Iv run a fuel system cleaner through it a few times.. But other than that, its basically untouched.
HELP! What could be causing such terrible mileage?
Thanks a ton :)
There is no such thing as strong coffee, only weak people.
treefrog99
Postby no_escape » Sun Mar 14, 2010 5:36 pm
new Plugs, wires, oil change, spray electronics cleaner on the MAF then let it dry, and fuel filter are the main ones I would start with
no_escape
Postby Ruski » Sun Mar 14, 2010 5:37 pm
air filter as well
Postby jetbtkng » Sun Mar 14, 2010 5:37 pm
any cell lites on, may be a blown knock sensor................. :drinking:
Postby treefrog99 » Sun Mar 14, 2010 5:41 pm
jetbtkng wrote:any cell lites on, may be a blown knock sensor................. :drinking:
Cell lights? You referring to the "error lights" or whatever you want to call them that appear on my dash? if so, none are on...
no_escape wrote:new Plugs, wires, oil change, spray electronics cleaner on the MAF then let it dry, and fuel filter are the main ones I would start with
Oil change every 5000km is done... but iv been thinking about new plugs and wires.
I was thinking the MAF could be dirty, where would I find electronics cleaner? What should I be looking for..
Could it be a dirty o2 sensor or a bad cat?
treefrog99
Postby Ruski » Sun Mar 14, 2010 5:43 pm
if you had bad a sensor your cel would be on
Postby no_escape » Sun Mar 14, 2010 5:46 pm
Electronics cleaner can be found at most auto parts stores. I bought mine at advanced autoparts. Not sure if canada has them.
no_escape
Postby treefrog99 » Sun Mar 14, 2010 5:48 pm
Ruski wrote:if you had bad a sensor your cel would be on
What about a dirty sensor though? Those dirty, dirty little sensors.. oh so dirty.. :bleep: my mind is in the wrong place right now, ignore me..
Well dont ignore the question though haha could it just be dirty, but not bad?
treefrog99
Postby jetbtkng » Sun Mar 14, 2010 5:49 pm
time for a tune up, new plug wires, & plugs, also check the air box and see if theres a blockage, also is it smoking, blue smoke.............. :drinking:
Postby treefrog99 » Sun Mar 14, 2010 5:54 pm
jetbtkng wrote:time for a tune up, new plug wires, & plugs, also check the air box and see if theres a blockage, also is it smoking, blue smoke.............. :drinking:
No smoke whatsoever... However when i really go WOT, I can smell a little oil burning I thnk
I think you are right about a tuneup though.. I shall start tomorrow!
Any other suggestions?
treefrog99
Postby treefrog99 » Sun Mar 14, 2010 5:59 pm
Also, would this be a good option for spark plugs?
http://cgi.ebay.ca/OBX-IRIDIUM-SPARK-PL ... 56392ada07
treefrog99
Postby no_escape » Sun Mar 14, 2010 6:19 pm
I didn't know OBX made spark plugs... or had NGK make some with the OBX label. :)
no_escape
Postby treefrog99 » Sun Mar 14, 2010 6:32 pm
Should be OK quality though, right?
treefrog99
Postby no_escape » Sun Mar 14, 2010 6:38 pm
I dunno, I haven't heard of a single person putting them in. The car came with Denso plugs and most stick with them. Some others, including myself, use NGKs'. All I know is don't use Bosch for our cars.
no_escape
Postby solara90 » Sun Mar 14, 2010 6:48 pm
id start out with the tune up
-Plugs
-Wires
-Air filter
-PCV Valve
-MAF cleaning
a bad 02 sensor could cause bad gas mileage but you should have a check engine light if it was bad
a clogged cat should trigger a check engine light also, and you would notice a bad smell like rotten eggs, it would also seem very sluggish when you accelerate
02 solara 2az
solara90
