SolaraGuy.com • View topic - Thre is something wrong with my car.
Postby loveImports » Sun Mar 14, 2010 11:02 pm
Hey guys, I haven't been here for a while. how's everything?
Anyways, I've been noticing more and more that rattling noises are coming from my front wheels. When I go more than 50 miles, I don't hear it.
I hear the noise every damn time, especially on uneven roads or bumps.
I had the struts replaced 2 years ago, and I don't know wtf.
Any suggestions ?
Thanks
V6 SE '99
All Stock
I Drive To Feel Alive
loveImports
Postby ThatVietGuy » Sun Mar 14, 2010 11:19 pm
Strut mounts.
ThatVietGuy
Postby treefrog99 » Mon Mar 15, 2010 4:53 am
I had the exact same problem! It was my Control Arm Bushings, there were just worn out...
Super cheep to fix, just got it done at my last oil change, it was like an extra 30 bucks..
There is no such thing as strong coffee, only weak people.
treefrog99
Postby solara90 » Mon Mar 15, 2010 10:55 am
so its a rattle not like a thumping, maybe a wheel is out of balance?
02 solara 2az
solara90
Postby SleeperSolara » Mon Mar 15, 2010 11:19 am
If it's your control bushin's, might as well get SuperPro.
Why replace wit OEM?? lol.
Postby loveImports » Mon Mar 15, 2010 12:33 pm
Come to think of, its more of a thumping. I had my balanced few months ago and the noise was still there.
God I hope its not the strut mounts
I am gonna get it checked out this friday
V6 SE '99
All Stock
loveImports
Postby jetbtkng » Mon Mar 15, 2010 12:40 pm
i just had greg replace my rear stut mounts, on my black lara, they were clunking bad, so i would think its the strut mounts, they do wear out................... :drinking:
Postby loveImports » Mon Mar 15, 2010 3:11 pm
I had my front struts replaced two years ago, and
my rear struts and strut mounts few months ago. And now this?!
Ok I will stop bitching. Does any one know how much it's going to cost me to replace the front strut mounts if it is the problem?
V6 SE '99
All Stock
loveImports
Postby mazen222 » Mon Mar 15, 2010 3:14 pm
loveImports wrote:I had my rear front struts replaced two years ago, and mm
y rear struts and strut mount few months ago. And now this?!
Ok I will stop bitching. Does any one know how much it's going to cost me to replace the front struts if it is the problem?
ya... you houldve replaced the mounts when you changed the struts...
i got strut mounts for 100$ on ebay and it cost 100$ to install.
Now my front strut are out :P
1999, 5 Speed V6
mazen222
Postby solara90 » Mon Mar 15, 2010 9:39 pm
it would be surprising if they put new struts in with out mounts... seems dumb to me. (well maybe job security)
02 solara 2az
solara90
Postby DaTwUnKrAziEpInOy » Thu Mar 18, 2010 12:24 am
PM Me...
DaTwUnKrAziEpInOy
Postby drewcrane » Fri Mar 19, 2010 3:53 pm
he yi had a rattle and once i got under there and just bounced a rubber mallet on a few things to make sure it wasnrt something simple
and sure enough it was a loose exhaust pipe bracket, dont know if this helps but just my 2 cents
"its a vanishing point thing you wont understand"
drewcrane
Location: 13.7 sec.s @bandimere ,5800 ft above sea level
Postby JvR » Fri Mar 19, 2010 3:59 pm
I think it is your homokyneet (i'm not sure it is the right word)
If you make a trun the sound must change.
JvR
