SolaraGuy.com • View topic - Front Left Wheel SHaking Problem
Postby mers714 » Wed Mar 17, 2010 10:16 pm
So after driving a few miles on the freeway at 60mph my left front wheel begins to shake, it shakes the steering wheel really badly. Can you guys help me with this problem? thanks
2000 Solara V6 SE AUTO - TRD RSB - TINT - 6K HID's
mers714
Postby QuickSEV6 » Wed Mar 17, 2010 10:31 pm
Your problem is one of two things. Either your wheels need to be balanced or you need a front end alignment.
Postby mers714 » Wed Mar 17, 2010 10:47 pm
i had my wheels rotated yesterday so it must be the alignment. Can it be the tie rods or ball joints or a bad shock? thanks
mers714
Postby ThatVietGuy » Wed Mar 17, 2010 11:02 pm
I'm guessing wheel bearing after alignment.
ThatVietGuy
Postby 1gSE » Thu Mar 18, 2010 4:17 am
I worked at a tire shop for 3 years and an alignment never caused a vibration. Either get the wheels balanced (might have thrown a weight) and check for a bent wheel. Did you feel a slight vibration in the seat or the body of the car before you got them rotated?
Solara-M62 @ 5.5psi
1gSE
Postby mazen222 » Thu Mar 18, 2010 6:10 am
since you got your wheels rotated ysterday, it looks like the guy didnt do his job properly.
I would go back there and let them re-bolt the tires properly. They have to be bolted cross way. Some mechs just do a rotation which causes the wheel to be slightly tilted and that causes vibration and eventually over use the tires. Dont drive on the freeway untill you get that fixed or you will scrap your tire
1999, 5 Speed V6
mazen222
Postby mers714 » Thu Mar 18, 2010 11:03 am
The wheel shaked before I got the them rotated
mers714
Postby xavier » Thu Mar 18, 2010 11:28 am
my steering wheel has shaked/vibrated between 55-70mph for the last ~6 years. I have still yet to find the problem. I have had the stock wheels balanced several times and my rims balanced several times and it shakes either way. I havent had an alignment for like 5 years so thats what Im gonna do when I shake off this laziness!
xavier
Postby mers714 » Thu Mar 18, 2010 10:50 pm
Should I take it to a shop to see what's wrong? Or go back to america tires to get the wheels balanced?
mers714
Postby 1gSE » Thu Mar 18, 2010 11:28 pm
mers714 wrote:The wheel shaked before I got the them rotated
Somehow I missed this post. Get all 4 wheels balanced, if it hasn't been done. Make sure nothing is loose up front, and check the bearings.
Solara-M62 @ 5.5psi
1gSE
Postby jetbtkng » Fri Mar 19, 2010 10:36 am
it could be a set of bad tires, had same problem, tried eveything, so i put my old tires back on, fixed it, so i took them back, they were replaced for free no more issues............ :drinking:
Postby treefrog99 » Fri Mar 19, 2010 6:31 pm
Hey dude, i can shed some light on this for you.. I had the exact same problem. My front caliper was gone... it wouldnt release properly, stuck on the brake disc... Just jack your car up and see how easily your wheel spins.. if it doesnt spin well, you might have that same problem..
I know some people may say that wouldnt cause wheel vibration, but it certianly did on mine. No more vibration once i got a new caliper...
There is no such thing as strong coffee, only weak people.
treefrog99
Postby mers714 » Sat Mar 20, 2010 10:20 am
thanks for the info. ill try to figure it out next week
mers714
Postby 99BlackSandv6 » Sat Mar 20, 2010 1:19 pm
I don't know if you have aftermarket wheels or factory.
But if they are aftermarket, you'll have centric rings.
If they are worn or damaged, you'll have a vibration.
Users browsing this forum: No registered users and 64 guests
