SolaraGuy.com • View topic - Caliper piston not retracting
Postby HydroponiK » Thu Mar 18, 2010 5:36 pm
A few days ago driving on the highway, my car started violently shaking so I pulled over to inspect but could not find any issues. When I got home however I noticed a small amount of smoke was coming out of the front passenger-side wheel well. The rotor didn't look smooth and the wheel was super hot.
I set up an appt for the dealer to check it out today, but when I got there the rotor looked fine. They inspected and said the caliper piston was sticky and not retracting properly. They offered to replace the calipers for $750 which I declined b/c that seemed way too much for the work being performed.
Does anyone know what would cause the caliper piston to not retract properly? Are there any cheaper fixes? I don't plan to keep this car much longer so not looking to throw a lot of money, but need it fixed for safety.
HydroponiK
Postby ASG14 » Thu Mar 18, 2010 5:59 pm
It;s called wear and tear.
ASG14
Postby ThatVietGuy » Thu Mar 18, 2010 5:59 pm
Cheapest would be to either rebuild it or replace it entirely. Either can be done yourself.
ThatVietGuy
Postby HydroponiK » Thu Mar 18, 2010 6:09 pm
Could the brake lines also cause the issue?
HydroponiK
Postby TLMNICK » Thu Mar 18, 2010 6:11 pm
Your brake lines are fine. It's just wear and tear. After a certain amount of time, and mileage, a caliper will seize. This will cause it to stick instead of retract.
I say get a rebuilt part and replace it yourself. It's easy.
TLMNICK
Postby HydroponiK » Thu Mar 18, 2010 6:30 pm
I'm not exactly mechanically inclined, especially with brakes. I could possibly bring it to a mechanic tho and have them replace it for me.
Is this the correct part I should be buying?
passenger side caliper
HydroponiK
