SolaraGuy.com • View topic - Does this happen to you guys?
Postby MisterTedster » Fri Mar 19, 2010 8:46 pm
Whenever I brake a little harder than normal and I go over a decently-sized crack in the road while braking, my abs turns on (and unnecessarily I might add).
Does this happen to you guys, or is my abs trigger happy? I'm always a little surprised whenever it happens since I usually never brake hard enough to get that weird pulsation through the brake pedal from the abs.
02 SE V6
MisterTedster
Postby ASG14 » Fri Mar 19, 2010 9:25 pm
Toyota's ABS ius WAY over sensitive. Same thing in both my '96 V6 Camry, my dad's '96 I4 Camry wagon, and mom's '05 I4 Camry.
ASG14
Postby ThatVietGuy » Fri Mar 19, 2010 9:31 pm
That happens to me, especially on the crappy stock all-season 16s or bald tires.
ThatVietGuy
Postby 99BlackSandv6 » Sat Mar 20, 2010 1:41 am
Yeah, I think it's the Toyota ABS sensitivity.
Haha, try autocrossing the car. :lol:
You'll get ABS in every braking zone, it sucks.
Maybe I'll try disabling it for an autocross this season. :think:
Postby DaZanY4002 » Sat Mar 20, 2010 1:56 am
When I brake all of a sudden while driving over some cracks or those lights on the street that line crosswalks, my brakes seem to skip a bit.
DaZanY4002
Postby stringbean » Sat Mar 20, 2010 2:16 am
hahaha happened to me today! ya it is quite annoying and very and not just you!
stringbean
Postby nemoxfishy » Sat Mar 20, 2010 3:16 am
happens so me too.... nothing to worry about!
nemoxfishy
Postby jimmm » Sat Mar 20, 2010 4:00 am
I'm 56 y/o, and I've been driving a long time. When I
first learned to drive, I was told that it is better to let
a car roll slowly over a pot hole without braking rather
than holding the brake while it drops into the hole. This
allows the drop to be less tramatic to both the car and
driver. To do this effectively, however, the hole must
be anticipated and sudden braking avoided as much as
possible. On another note, in this first year of driving
and owing my Solara, I have not experienced any
of the ABS sensitivity issues aforementioned in this thread.
jimmm
Postby DriDed » Sat Mar 20, 2010 5:16 am
The abs on my car is not trigger happy on dry roads but on wet roads yea.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby ASG14 » Sat Mar 20, 2010 8:28 am
99BlackSandv6 wrote:Yeah, I think it's the Toyota ABS sensitivity.
Unhook the ABS pump harness. Sets the ABS light off disabling the ABS system. Plug it back when done, ABS back on. :)
ASG14
Postby 99BlackSandv6 » Sat Mar 20, 2010 12:57 pm
^Yeah, I think I'll try that next time I autocross. :sweet:
Postby 02slera » Sun Mar 21, 2010 7:47 am
this is strange. i own an 02 solara and i've never experienced such an issue. my car has 125k miles. (tho ive only owned it since about sept 09 and 105k miles)
2002 Solara SLE v6
02slera
Postby solara90 » Sun Mar 21, 2010 9:05 am
i dont have ABS so no problem for me
02 solara 2az
solara90
Postby timefourfood » Sun Mar 21, 2010 12:45 pm
i only saw the abs light up once during a huge storm when I braked, i guess the road was slick enough to cause it. other than that never had, mine isn't sensitive or that i never braked that hard. i gradually brake to have a smooth stop.
2000 SLE coupe
timefourfood
Postby youngblood » Tue Mar 23, 2010 1:57 pm
jimmm wrote:I'm 56 y/o, and I've been driving a long time. When I
possible.
Great advice, Jimmm.
All you have to do let off the brakes for the half-second it takes to traverse the bump/ hole. Then, continue to brake normally. This 'unloads' the front suspension and returns the nose of the car to it's normal ride height. This way there is more suspension travel available to 'smooth out' the bump. Also, the weight of the car is shifted forward when you hit the brakes. This puts more demand on your springs/ struts as they slam across imperfections in the road.
More on topic-- no issues with my Gen2 abs being over sensitive.
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
