how hard would it be to change the timing belt?
i need to change my timing belt horribly! how hard would it be?
2001 SLE | 20% Tint | Coming soon = wheels
- pepowdylan
- Regular SolaraGuy Member
ASG14 wrote:If your asking it that vuagely, you can;t do it.
SpeedySolara wrote:ASG14 wrote:If your asking it that vuagely, you can;t do it.
haha...I like how you put that BUT considering you know how to do it, you could try to help the guy out.
It's a very time consuming job and one you shouldn't attempt considering how important it is. In short, to the left of your motor on the bottom there is a black plastic cover where the timing belt is under. You need to take it off and replace the timing belt. If I'm not mistaken, there are markings on the belt and motor and you have to know where to match up the belts. You should do the water pump if you're in there already. Enjoy!
Eye8Pussies wrote:Non- interference engine, so he'll be fine either way
And just give yourself an entire day for your first time and just keep your fingers crossed when you fire it back up in regards to timing as it is really easy to set the timing off by a tooth due to the lack of room to work with.
If you are also planning on changing the cam seals, give yourself more time as well, as the bank1 seal is a bitch to get in and out without scratching anything or damaging the seal.
pepowdylan wrote:Well I'm pushing 140k on the original timing belt, and its making noise. Time to change it. No, I haven't changed it before, but I know my way around a car kind of. haha.
I just don't have the 400 - 600$ to drop on it to change it.
