SolaraGuy.com • View topic - New Carpet... Is camry carpet the same?
Postby Slut » Sun Mar 21, 2010 6:56 pm
I cant find online anywhere to find a carpet for a solara... But I can find for a camry.. My question is, is the carpets the same in the 97-01 camry?
Slut
Postby alltrac92 » Sun Mar 21, 2010 7:50 pm
One is a two door the other a four.
alltrac92
Postby 99BlackSandv6 » Sun Mar 21, 2010 8:35 pm
I think KILLA CAM is experienced on this. Ask him.
I think they're the same, but I'm not 100%.
Postby Gibson99 » Fri Apr 16, 2010 10:56 am
they won't be the same because the place where it goes up for the B-pillar is in a different place, not to mention the fact that the 4dr has to go under another door threshhold where the solara doesn't, so the carpet will be different for the back, too. otherwise they're probably similar/identical across the center tunnel and front floorboard area. only way to know for sure would be to put the two side by side, and most junkyards probably won't let you do that... :/
Gibson99
Postby KILLA CAM » Fri Apr 16, 2010 11:45 am
^They are not different. I have an OEM Gen 1 Solara carpet in my Gen 4 Camry.
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby 1st Gen Sol » Fri Apr 16, 2010 2:20 pm
I bought an aftermarket carpet from www.autoupholsterykits.com awhile back for my 4dr Camry. It was a pain in the *** cutting out all the holes for the seats to bolt down, vents, seatbelts and everything else.
You can make the carpet work in the Solara b/c I remember a member on the forum doing it here awhile back with the aftermarket Camry carpet, you'll just have to cut a lil more here and there.
The carpet will form to the Solara when you leave it in overnight and let it sit. I wouldn't suggest taking a heat gun to it but sitting in the sun works good.
Heres a few pics of how the carpet looks.
Hope my 2 cents helps you out.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby vSolara » Sun Apr 18, 2010 5:50 pm
I've had 97 Camry mats in my 01 solara. They fit fine, except I think the drivers side "clip" doesnt match the hole.
2001 Toyota Solara SLE V6 - Tinted Windows, Pioneer DEH-2100IB, Pioneer Door Speakers, Custom DIN voltmeter/switchboard, interior accent LED strips
vSolara
