SolaraGuy.com • View topic - Good ground location / Remove backseat
Postby vSolara » Mon Mar 29, 2010 8:03 pm
Today I did the wiring for a new subwoofer. I was able to run the main power, RCA and remote wire. But I can't find a good grounding location. I've read about the seat belt bolts, but I can't seem to get the bottom of the back seat off. How do I pull on it to get it off? Or, is there another location?
Thank you!
2001 Toyota Solara SLE V6 - Tinted Windows, Pioneer DEH-2100IB, Pioneer Door Speakers, Custom DIN voltmeter/switchboard, interior accent LED strips
vSolara
Postby ThatVietGuy » Mon Mar 29, 2010 8:11 pm
Just grab the bottom cushion (the part you sit on) and pull up hard. Not much more to it than that...
ThatVietGuy
Postby vSolara » Mon Mar 29, 2010 8:23 pm
Thanks for the fast response, I'll try it out tomorrow.
vSolara
Postby kenny6683 » Tue Mar 30, 2010 10:00 am
i just drilled a small self tap screw down on the metal right behind back seat. worked light a charm
kenny6683
Postby MisterTedster » Tue Mar 30, 2010 11:34 am
^ x2
02 SE V6
MisterTedster
Postby cj145 » Tue Mar 30, 2010 6:09 pm
The best ground is into the frame rail somewhere in the trunk (assuming you don't run copper...). If you don't have a really high powered system you can use just about any place in the trunk. I used a thicker part of the rear seat brace behind the plastic cover.
cj145
Postby HydroponiK » Thu Apr 01, 2010 5:37 pm
I went ghetto and used one of the holes under the rear speakers inside the trunk.
HydroponiK
Postby pepowdylan » Thu Apr 01, 2010 8:15 pm
I just screwed it onto the metal behind the back seat, works like a charm.
2001 SLE | 20% Tint | Coming soon = wheels
pepowdylan
