SolaraGuy.com • View topic - power outlet, cigarette lighter, and clock quit working....
Postby robwilson4040 » Sat Aug 09, 2003 7:48 pm
a few days ago, i noticed that my power outlet had quit working, so i plugged my phone into my cigarette lighter, and the next day that too went bad, and later that day i noticed the clock is no longer on at all....... and i cant find a bad fuse, does anybody have a suggestion??
robwilson4040
Postby krawzyazn » Sat Aug 09, 2003 7:49 pm
change the fuse for it anyways
also....
Postby robwilson4040 » Sat Aug 09, 2003 7:59 pm
also, the fusebox cover doesnt have that labeled..... so i dont even know which fuse goes to it
anybody know that??
robwilson4040
Postby Yanks0114 » Sat Aug 09, 2003 8:00 pm
owners manual should have info about the fuses and a picture of which goes where
one more question about it
Postby robwilson4040 » Sat Aug 09, 2003 8:06 pm
first, the manual was no help with labeling the fuses, unless i overlooked it but i dont think i did.....
and my other question is: once i get it working again, does anybody know how to rig the power outlet so that it will work even when the car is completely off?
thanks
robwilson4040
Re: one more question about it
Postby Yanks0114 » Sat Aug 09, 2003 8:12 pm
thanks
Take a voltmeter and find out which one is the hot (12V) and cut the wire. Then run a 12 volt constant (Either from the fuse box) or from any other constant source.
You can either tap the door locks fuse, power seats or any accessory which can work when the car is off.
You could also run it directly to the battery, but thats a big project
Postby FLASH » Sat Aug 09, 2003 9:12 pm
Same thing happened to me a while ago, and it was my fuse. It IS in the manual somewhere, for some reason I think the fuse number is 21...? Ill check later if I get the time, but I think thats your problem.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Astro » Sat Aug 09, 2003 10:41 pm
I had the same problem. There is a label listing the fuses on the back side of the panel, next to the hood release.
