SolaraGuy.com • View topic - Coolant issue that makes no sence!!!
Postby thatdamngoodcire777 » Tue Apr 06, 2010 7:54 pm
I have pink coolant in my car and I had refilled it with green coolant. After a few days, all of the green coolant dissapears and the pink coolant reappears and it comes out filthy. It looks like there's a leak on the drivers side of the car and no leak where I put in the coolant. My car is not overheating and no sensors are on. I get regular oil changes and my cars fluids are up to date. My car looks like its sucking up the new fluid because bubbles are coming from the hose where the coolant container is. Also, I hear liquid swishing around in my car that sounds like its gurgling. Don't know what that is either. I don't know how the green coolant can dissapear WITHOUT overflowing or leaking from the coolant container?? I didn't have a coolant flush since I had the car and I don't know if it could be as easy as that. What could this be and how can I fix this myself?
thatdamngoodcire777
Postby ASG14 » Tue Apr 06, 2010 8:15 pm
Dude, PLEASE tell me you did NOT mix the green and the pink coolant.....
ASG14
Postby 1gSE » Tue Apr 06, 2010 8:34 pm
Is this another april fools joke?
Solara-M62 @ 5.5psi
1gSE
Postby onefiend » Tue Apr 06, 2010 9:10 pm
Read your owners manual. Toyota cars are suppose to use Toyota brand Long Life Coolant (red) or Super Long Life Coolant (pink).
onefiend
Postby alltrac92 » Tue Apr 06, 2010 9:41 pm
Toyota red: Ethylene Glycol(107-21-1),Diethylene Glycol(111-46-6) Water(7732-18-5) Orangic Acid Salt(532-32-1) Hydrated Inorganic Salt(1310-58-3)
Toyota pink: Water (7732-18-5), Ethylene Glycol (107-21-1), Diethylene Glycol (111-46-6), Sebacic Acid (111-20-6), Potassium Hydroxide (1310-58-3)
I would not mix red with pink or with any other color.
alltrac92
Postby onefiend » Wed Apr 07, 2010 8:42 am
alltrac92 wrote:I would not mix red with pink or with any other color.
You can add Toyota pink to a car filled with Toyota red, not the other way around.
onefiend
Postby ozone » Wed Apr 07, 2010 10:03 am
It's not the end of the world. It will still keep the car cool. I believe the reason for the different coolants is to make sure they are compatible with the materials that make up your cooling system. Over time a different fluid may break down a seal or something. It might be a good idea to flush the system and put the correct fluid in with an acceptable ratio of water.
As far as the color and appearing and disappearing go, I'm a little confused as to what you mean. Here's what I think you mean:
The coolant appears and disappears from the overflow reservoir under the hood. If that's the case this is normal. When the car heats up, the pressure in the system increases until the spring in your radiator cap is compressed to the point it uncovers a little hole that allows the pressure to force the fluid into the bottle and it "appears." When you shut the car off, the system cools down, the pressure drops and the fluid is sucked back into the cooling system and "disappears." This is completely normal.
As far as the color change is concerned, the two fluids have probably incompletely mixed giving you the appearance of one or the other color or some other nasty color where the two have mixed well.
If you have some on the ground under the car, this can also be normal depending on your car and how much is there. Sometimes the little tube that goes from the radiator to the overflow bottle leaks a little or if the fluid comes out vigorously some will escape through various places, like the lid on the bottle which is not a perfect seal, etc. If it's a lot, then you may be overheating. If the temperature never rises, but you are boiling over, you need to change your radiator cap. If the problem continues, you should definitely check the temperature sensor.
That's about the best I can do for diagnosis without actually seeing the car. Plus the radiator cap is sometimes on the bottle and not on the radiator. I don't know which one you have, but the general principles still apply. Check your system. Flush the radiator and fill it up. Often when you first fill it, the fluid doesn't get into every nook and cranny of your system but the first time the fluid is sucked in, it will all be gone as those areas fill up. Just add a little more. It's normal.
Good luck. I hope this helps.
ozone
Postby thatdamngoodcire777 » Mon Apr 12, 2010 2:28 pm
Sorry, I'm a newbie. Thanks for all the info. I'll try the "red" coolant instead of green and keep an eye on the radiator. One more thing...how do I give my '00 Solara a coolant flush? Thanks again!
thatdamngoodcire777
Postby Mole » Mon Apr 12, 2010 3:48 pm
thatdamngoodcire777 wrote:.how do I give my '00 Solara a coolant flush? Thanks again!
go to your dealer.
