SolaraGuy.com • View topic - Removing Solara And Toyota logo
Postby MarcoSolara02 » Sat Apr 10, 2010 9:48 pm
Ive been thinking of removing the back logos, any advice on how?
Last edited by MarcoSolara02 on Sat Apr 10, 2010 10:02 pm, edited 1 time in total.
[img][IMG]http://i116.photobucket.com/albums/o17/s14marco/0702001319a.jpg[/IMG][/img]
18" SSR Wheels, 20 % Tint all around, Trd muffler, Eibach/Tokico.
MarcoSolara02
Re: Removing Solara And Toyota
Postby wkbrdr91 » Sat Apr 10, 2010 9:51 pm
MarcoSolara02 wrote:Ive been thinking of removing the back logos, any advice on how?
Ive heard some type of soap, or maybe goo-gone plus floss (to get it off car) works, and make sure to wax the area after, might have to buff it, there could be a mark where it used to be from fading.
2006 Solara Sport
wkbrdr91
Postby SdeA » Sat Apr 10, 2010 9:52 pm
First use a hair dryer. Then use flosh to remove the logo.
SdeA
Postby MarcoSolara02 » Sat Apr 10, 2010 10:03 pm
how long do i heat it for or wha?
MarcoSolara02
Postby ThatVietGuy » Sat Apr 10, 2010 10:16 pm
No time frame. Probably not long these days since it's warmer.
Just keep moving the hair dryer over the emblems to soften the glue enough so that you can pass a string of floss behind the emblems.
ThatVietGuy
Postby Mr_Chunkz » Sat Apr 10, 2010 11:28 pm
for me i heated it long enough to where the floss didnt fray
then kept sliding back and forth.... didnt break the floss through the whole emblem. Also, mine left lots of sticky residue. Goo gone, lots of rubbing and a paper towel got rid of that stuff. Then it was just a matter of cleaner wax, and a good sealer wax and its done.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby jong2be » Sun Apr 11, 2010 12:09 am
In my case, I repaint my all emblems for black last night.
*hotwater(if it's really hot, it's not good for paint so just boil 2-5 min then put iron fork to check temperature) & costco card or plastic card (removing tool)
1. pour hot water over emblem (it works as dryer and lubricating oil, and it's faster than dryer)
2. when emblem is warm, start remove emblem with plastic card
3. while removing emblem, spray some water again and again (to keep emblem is warm)
in my case, I just took 15 min to remove all emblems last night.(I started it 3 a.m. lol)
good luck!
http://www.cardomain.com/ride/3812488/2 (If U wanna see bigger pics, you can see em in here)
2006 Toyota Solara
(Still, my grammar is sucks! plz understand it. lol)
jong2be
Postby k-0tik » Sun Apr 11, 2010 3:07 am
fishing wire, came off in like a minute for me.
k-0tik
Postby 02slera » Sun Apr 11, 2010 4:37 am
^^ yes fishing line worked much better for me than anything else. i heated up with hair dryer until emblem feels warm/hot, the use fishing line as floss to remove emblem. also, i found that goo gone doesn't work so well as bug and tar remover and an old sock to get the left over glue off
2002 Solara SLE v6
02slera
Postby onefiend » Sun Apr 11, 2010 9:28 am
Mr_Chunkz wrote:Goo gone, lots of rubbing and a paper towel got rid of that stuff.
I wouldn't ever suggest lots of rubbing using a paper towel to use on any car with a good looking paint job. Paper towel's scratch the clear coat, you can see the damage it causes if you're under the sun. Better to use a 100% cotton towel or a microfiber towel.
2007 Camry SE V6
onefiend
Postby solara90 » Sun Apr 11, 2010 11:27 am
i used some 50lb fishing line only broke twice removing mine, then i used goo gone to remove all the sticky crap which is most time consuming. Then went over it with wax and my buffer and you could never tell they were there
02 solara 2az
solara90
Postby MarcoSolara02 » Sun Apr 11, 2010 5:37 pm
I used goo gone, but the outline of the logos is still there, its not VERy visible, but visible.
MarcoSolara02
Postby gee_xiong » Sun Apr 25, 2010 5:00 pm
thanks..that was helpfull ya...i had my lara for a while and always thought about it but never did anything about it...now i am...haha...sound so easy...
gee_xiong
Postby solara1989 » Sun Apr 25, 2010 9:49 pm
I thought the "Solara" emblem on the trunk was screwed on the trunk...
2000 Solara SLE V6 Diamond White
solara1989
Postby Toy1mzfe » Sun Apr 25, 2010 9:54 pm
nope... all are removable on the trunk.^^
