SolaraGuy.com • View topic - 99 toyota solara light issues
Postby Sharpie » Sun Apr 18, 2010 8:35 pm
I recently had some body work to my 99 Toyota Solara. After about a month I noticed that my dome light didn't work when I would open the door and the switch was at door and my A/C lights on the center console didn't work. Is it most likely a fuse or a wiring problem?
Sharpie
Postby TLMNICK » Sun Apr 18, 2010 9:43 pm
Does the domelight work if you open the passenger door?...if it does, then it's quite possible that you have a faulty door switch on the driver side.
if the gauge cluster lights up, but the AC controls don't, then you'll have to go into that piece, and change some bulbs.
TLMNICK
Postby freshdenamufcka » Sun Apr 18, 2010 11:50 pm
had same problem. just change the fuse
freshdenamufcka
Re: 99 toyota solara light issues
Postby carolyndickinson » Mon Jul 18, 2011 7:09 pm
I have a somewhat similar issue. I do not have an owners manual or a repair manual. I do however have the fuse diagram on the back of the coin holder. Do you know which one is the dome light? I'm trying to determine if I need to replace the fuse or the bulb or maybe I have a short. The light is completely out and does not turn on manually or when I open the door. I am not having any other electrical issues that I know of.
Secondly, where can I find a description for the fuse diagram? Everytime I have a fuse issue I have to search for hours to figure out which one. Please help me :)
carolyndickinson
Postby TheGreenDutch » Tue Jul 19, 2011 10:46 am
probably a bad bulb...upgrade to LED. Also my left side temp control console light works if I smack the console a couple times. lol...
TheGreenDutch
