SolaraGuy.com • View topic - Car shakes when I let off gas on same gear
Postby mig0s » Thu Apr 29, 2010 5:38 pm
Hey y'all,
When I'm on my 2nd and 3rd gear, and when I let off the gas pedal, the car slows down and shakes (not too hard) and seems like it would stall, even with my RPM is still higher than 1000 (I'm not pressing the clutch). Then when I press on the gas again, the car would shake a little more until i'm constantly accelerating. Is this normal in manual cars or I've got a problem?
Thanks for your advises
mig0s
Postby NXRACER » Thu Apr 29, 2010 10:24 pm
you know, i had something similar to this... i had my tires balanced-they were good, checked my custom toe setting & put back @ stock-still there, new axles-still nope!.. i cant diagnose further yet tho because my timing belt broke (wondering if that was it?)
im @ 224,000 miles what is your milage & when was your last tune up?
-'92 Camry Base, MT, 5S-FE--- mostly stock sofar
NXRACER
Postby Mole » Thu Apr 29, 2010 11:32 pm
motor mounts ?
Postby ---CAMRAZY--- » Fri Apr 30, 2010 12:18 am
Wheel balancing??? Half shafts?
Postby mazen222 » Fri Apr 30, 2010 5:55 am
i think thats normal, especially if you have a new clutch. RPM should not be less than 2 if you're moving.
i'm pretty sure that if you press the clutch pedal the shaking would stop... this tells you its not the wheels, its the clutch.
1999, 5 Speed V6
mazen222
Postby 01SilverSolara » Fri Apr 30, 2010 9:13 pm
check your brake calipers. I just had the same issue recently (although my car is an auto). Let off the gas and the car started shaking, pulled over and got out and could smell the over heated brake lining. Drivers side caliper was sticking, badly.
Just a thought.
01SilverSolara
Postby mig0s » Fri Apr 30, 2010 9:31 pm
My brakes are practically new and no weird smells in my car or whatsoever. And yes I know that when I press the clutch it stops shaking. Hopefully it's just normal in manual transmissions.
Thanks for advises, i'll soon get the car thoroughly inspected and keep you guys updated
mig0s
Postby mazen222 » Sat May 01, 2010 6:25 pm
mig0s wrote:My brakes are practically new and no weird smells in my car or whatsoever. And yes I know that when I press the clutch it stops shaking. Hopefully it's just normal in manual transmissions.
CAA is a very good place for that. almost 200$ but well worth it. there's like 3 in mtl
1999, 5 Speed V6
mazen222
