SolaraGuy.com • View topic - No pressure in brake pedal
Postby vman5911 » Fri Apr 30, 2010 8:38 pm
Removed my calipers today to paint them. Just the rears. Attempted to bleed the two rear calipers. The left rear bled alright. The right rear feels like there is no pressure when I open the bleed valve. Please help!
The good news is that the paint came out nice.
vman5911
Postby 02slera » Sat May 01, 2010 9:24 am
im not sure on this but you may be able to replace that valve, if not i would THINK new caliper is in order. hopefully someone who knows more will post up.
2002 Solara SLE v6
02slera
Postby 99BlackSandv6 » Sun May 02, 2010 1:25 am
Not sure what you mean. Do you mean that there is no pressure coming out of the bleeder? If that's it, you probably just have air still in the line, or you have a clogged bleeder.
Postby EEngineer » Sun May 02, 2010 1:41 am
or you haven't tightened the bleeder nipple enough
94 Camry 3VZ 5 spd swapped - parted out 2009
92 ES300 3VZ 5 spd supercharged @ 300.8whp
99 Solara 1MZ 5 spd bone stock (not for long)
EEngineer
Postby dug320 » Mon May 03, 2010 8:34 pm
No pressure means AIR. Bleed bleed bleed.
dug320
Postby dudutzu » Tue May 04, 2010 7:28 pm
any brake fluid left in the reservoir?
dudutzu
