SolaraGuy.com • View topic - Screwed up, need estimate
Postby Cubez2701 » Thu May 13, 2010 5:40 pm
Well I lubricated my rsb bushings bout two months ago and I guess I didn't tighted the bolts enough cause one came loose while doing a sharp turn. Luckily the only damage was one sway bar bracket, it was bent almost straight (Still not sure how that happend). I was just wondering if any one knew how much those brackets cost dealership and junk yard.
Cubez2701
Postby ThatVietGuy » Thu May 13, 2010 6:03 pm
Well, junkyard is free if you know where to hide things.
ThatVietGuy
Postby ASG14 » Thu May 13, 2010 6:08 pm
Like $10 at dealer, OR just bend yours back.
ASG14
Postby Cubez2701 » Thu May 13, 2010 6:48 pm
I thought about bending it back, but if it's bout 10 bucks at the dealership it's not worth the hassle. Thanks
Cubez2701
Postby ASG14 » Thu May 13, 2010 7:32 pm
Actually, it may be $8 each, lol.
ASG14
Postby SleeperSolara » Thu May 13, 2010 10:21 pm
Like what "ThatVietGuy" said, go to a salvage yard pick one off a Gen 4 Camry, and you'll be set.
Postby MisterTedster » Fri May 14, 2010 12:46 am
I might have some extra brackets somewhere. I'm currently using Energy bushings which come with their own brackets and the toyota brackets didnt fit them, so I should have them laying around somewhere.
Energy bushings don't squeak in case you were wondering.
02 SE V6
MisterTedster
Re:
Postby Cubez2701 » Tue May 18, 2010 7:03 pm
MisterTedster wrote:I might have some extra brackets somewhere. I'm currently using Energy bushings which come with their own brackets and the toyota brackets didnt fit them, so I should have them laying around somewhere.
Ive should have logged in earlier I actually, I ended up picking one up from the dearlership for $16.00. As for the Energy bushings are they for the stock or trd sway bar?
Cubez2701
Re: Screwed up, need estimate
Postby MisterTedster » Tue May 18, 2010 8:42 pm
The Energy bushings are universal, so I just got the ones that fit the TRD sway bar diameter. I can't remember what the diameter is off the top of my head, but I know someone can chime in what the diameter is.
02 SE V6
MisterTedster
