SolaraGuy.com • View topic - Tail lights out
Tail lights out
Tail lights out
Postby vman5911 » Sat May 22, 2010 11:08 am
Hey guys,
So some guy told me my tail lights were out yesterday. Brake lights good. Turn signals good. Hazards good. Checked the fuse. It was blown. Put a new 10a in there and it blew again. Any ideas what could be going on?
My dashboard dimmer also seems to be constantly on, which seemed odd, if that gives anymore clues.
Thanks.
vman5911
Re: Tail lights out
Postby LEE337 » Sat May 22, 2010 4:15 pm
did you replace the bulb?
Re: Tail lights out
Postby vman5911 » Sat May 22, 2010 5:21 pm
Yeah, the bulbs are fine
vman5911
Re: Tail lights out
Postby LEE337 » Sat May 22, 2010 6:01 pm
Oh, so they both went out at the same time but not the brake lights?
Sounds like a ground problem.
PM Gabe (TRD4life)
He had the same problem a month or so ago, and I cant remember how he fixed it.
....but Im pretty sure it was a ground problem.
Good Luck
Re: Tail lights out
Postby vman5911 » Sun May 23, 2010 4:38 am
Thanks, I'll give it a shot
vman5911
Re: Tail lights out
Postby TheGreenDutch » Sun May 23, 2010 3:31 pm
check for a short. Maybe water corroded a wire? or a pinched rust spot that got yanked finally.
TheGreenDutch
Re: Tail lights out
Postby solara90 » Sun May 23, 2010 4:18 pm
there has to be a short somewhere check wiring from bulbs back
02 solara 2az
solara90
Re: Tail lights out
Postby vman5911 » Sun May 23, 2010 5:43 pm
I also noticed that the headlight dimmer turns itself on when my car is in drive, but turns off when my car is in neutral, if that provides any other clues.
vman5911
Re: Tail lights out
Postby TheGreenDutch » Mon May 24, 2010 6:58 am
either get an exorcist or follow the wires....lol That sounds weird. Something going on around the shift cables? Relay?
TheGreenDutch
Re: Tail lights out
Postby vman5911 » Mon May 24, 2010 8:36 am
I'm thinking it could possibly be the relay too...what would be the symptoms? And does anyone have a simple diagram of where the relay would be?
vman5911
