SolaraGuy.com • View topic - Misfire in Cylinder 1 3 4 5
Postby danielsle99 » Sun May 23, 2010 9:25 pm
At first cylinder 1 and 4 were misfiring and i believed it to be the coil but now 1 3 4 5 are. Is there any possibility that the camshaft sensor is the cause of this? I just replaced the spark plugs and wires.
danielsle99
Re: Misfire in Cylinder 1 3 4 5
Postby 1gSE » Mon May 24, 2010 12:53 am
The entire rear bank is misfiring? Was it before you replaced the plugs and wires or after? I'd double check the wires and make sure they're going to the right cylinders.
Solara-M62 @ 5.5psi
1gSE
Postby TheGreenDutch » Mon May 24, 2010 7:04 am
if it happened as soon as you finished the wires and plugs check the firing pattern of your wires.
TheGreenDutch
Postby danielsle99 » Tue May 25, 2010 1:16 pm
it was misfiring before and after. all the plugs are going to the right spot. i might just have to take it to a shop to get it looked out
danielsle99
Postby 02slera » Tue May 25, 2010 5:53 pm
your engine runs on 2 cylinders? i must be misunderstanding this. how do you know 1, 3, 4 and 5 are miss firing?
2002 Solara SLE v6
02slera
Postby TheGreenDutch » Tue May 25, 2010 6:45 pm
coil packs!
TheGreenDutch
Postby danielsle99 » Tue May 25, 2010 8:35 pm
Ive had the computer tested and it came up with 1 3 4 5 misfiring
danielsle99
