SolaraGuy.com • View topic - Anyone know what this is?
Postby ozone » Thu May 27, 2010 4:34 pm
World's first V6 powered AE92. . . in progress.
ozone
Re: Anyone know what this is?
Postby TxBmbleBee » Thu May 27, 2010 5:25 pm
yea its the lines for the brake fluid that go to the clutch on the tranny
"i just wanna go fast..."
TxBmbleBee
Postby ozone » Thu May 27, 2010 8:21 pm
Could you be more specific? On my Corolla, the line just goes straight from the master clutch cylinder to the slave cylinder. The piece in between seems to serve no purpose.
I'm guessing it must lower the pressure or maintain the pressure when the clutch isn't pressed or something. The book calls it a "clutch accumulator" but doesn't bother to explain what that means.
ozone
Postby TxBmbleBee » Thu May 27, 2010 9:03 pm
personally, when I did my swap...i bypassed it completely. however gibson told me its actually kind of important. I havent driven my solara enough to know if i should use it or not. But so far my car works without it.
BTW i have read that king does not use it either and bypassed it. hope this helps...
TxBmbleBee
Postby 02slera » Fri May 28, 2010 2:25 pm
an accumulator is kind of a storage,
it stores energy in this case (or power),
whether or not you really need that extra energy in your clutch i dont know,
apparently toyota thought it was needed.
check out this link for some interesting info on the subject:
http://www.dsmtalk.com/forums/showthread.php?t=134652
2002 Solara SLE v6
02slera
Postby Eye8Pussies » Fri May 28, 2010 3:41 pm
yeah, it's the clutch accumulator...some theorize that it can make clutch engagement easier since it will allow a bit of pressure to build before atively disengaging the clutch
and yes, I bypassed mine when I did my 5-speed swap as well since the lines going to it were all seized. No difference in performance
