SolaraGuy.com • View topic - Air Conditioning
Air Conditioning
Air Conditioning
Postby dug320 » Mon May 31, 2010 12:04 am
My 1999 Solara SLE is not producing cool air with the A/C on. While I am slowly working through all the tests any insights would be invaluable.
The A/C relay works. The fuse is not blown. The magnetic clutch engages and disengages. The A/C switch on the panel works. T
The DTC shows 00. Even after clearing the codes it will show 00.
If it is the Evaporator Temperature Sensor where is it so I can test it.
dug320
Re: Air Conditioning
Postby ThatVietGuy » Mon May 31, 2010 1:57 am
Perhaps it needs a recharge?
ThatVietGuy
Postby 02slera » Mon May 31, 2010 6:04 pm
^^yes
you can buy a recharge kit for around $30 at an autoparts store that comes with a gauge to measure psi so you can see exactly where you stand on refrigerant levels.
2002 Solara SLE v6
02slera
Postby TheGreenDutch » Tue Jun 01, 2010 12:52 pm
yeah man its all dried out....Get a recharge done or buy the specific kit. If you trust your mech its about $30-60 to recharge the system.
TheGreenDutch
Postby solara90 » Thu Jun 03, 2010 3:47 pm
Well not all states allow the sale of R-134 in the small cans I.E. Wisconsin. Did your A/C work before? if it did you most likely have a leak some where, or missing the caps on your A/C lines.
Also if you do have a leak if suggest go to a professional and get if fixed, they can pretty damn hard to find sometimes. Most off dont just throw some sealant in it if you want someone to recover and refill your system again. Most places are very fussy about sealant and their $6,000 machines.
I can help you a lot in this area, I just got certified this year in school to work on automotive A/C systems :-)
02 solara 2az
solara90
Postby dug320 » Fri Jun 04, 2010 12:46 am
Thank goodness the oil can be see under a blacklight. It turned out to be the compressor shaft seal.
To answer your questions. It worked fine last time I used it. There is some gas in the system as I can see a small air bubble in the window. I would never use sealant.
dug320
Postby TheGreenDutch » Fri Jun 04, 2010 12:21 pm
your lucky the magnet on the pully to my a/c compressor is off and makes a finger in a fan noise every once in a while. I still got air tho...whew!
TheGreenDutch
Postby LatinDragonXJC » Sun Jun 06, 2010 10:02 am
How often do you guys recharge your A/C?
I think I may have a leak, I have to recharge it every year. (my family owns a Refrigeration/AC shop, so it's free)
It works great throughout the summer, but soon as next summer comes....hot air!
How hard is to seal up a leak?
LatinDragonXJC
Postby dug320 » Fri Jun 11, 2010 7:58 am
Don't just seal the leak fix it. Shame, shame you should know better. Ask the people in the shop how they feel about sealant.
dug320
Postby solara90 » Fri Jun 11, 2010 7:14 pm
yeah, dont use sealant, use a leak detector or use a ultraviolet dye in your system to find the leak!
02 solara 2az
solara90
Postby dug320 » Sun Jun 13, 2010 10:49 am
The oil in A134 has an ultraviolet dye in it. No need to add anything. A simple blacklight in the dark will do the job of illumination.
dug320
Postby 02slera » Sun Jun 13, 2010 11:23 am
^^ lol i just bought a recharge kit that has dye in it. what the hell is the point of that if all of this refrigerant has ultraviolet dye in it? anyway i just charged mine this morning and its blowing cold for now. when i removed the kit from the low side port on the car it was spraying back past the valve on the car and i got hit in the eye with dye, when the instructions say wear eye protection they mean it. i used a small screwdriver to press the valve in and released it quickly and it seems to be sealed, better anyway. i suspect i will have a small leak from this valve still but if that is the only leak i have i am lucky.
2002 Solara SLE v6
02slera
Postby solara90 » Sun Jun 13, 2010 12:38 pm
did you put the black cap on it? the schrader valve is actually the secondary seal. The cap is the primary seal.
02 solara 2az
solara90
Postby dug320 » Sun Jun 13, 2010 9:03 pm
The oil is ultraviolet sensitive. Sometimes the valves get frozen in place during the recharge.
dug320
