SolaraGuy.com • View topic - clutch pedal is very stiff...need help or advise
Postby kenny6683 » Wed Jun 02, 2010 1:29 pm
ever since i got my solara the clutch pedal has always required alot of pressure to push down.
Is there anyway to adjust the tension or the pedal so that it's a bit loose and easier to shift?
i'm dying in new york traffic with this damn clutch pedal lol
kenny6683
Re: clutch pedal is very stiff...need help or advise
Postby Eye8Pussies » Fri Jun 04, 2010 10:20 am
check/replace your slave and/or master cylinder- hey are basically the only things that really affect how stiff your clutch is besides for your pressure plate
Postby redsamick » Wed Sep 01, 2010 10:08 pm
The clutch on my '00 is stiff as well. I'm just replying to save this thread so I can reference it again when I get home. Thanks for the info Eye8!
2000 SE 5-speed
V6
K&N Air filter
Black
Sunroof
Leather
time flies like an arrow. fruit flies like a banana.
redsamick
Postby mazen222 » Sun Sep 05, 2010 6:52 pm
pressure on mine changes... its usually soft with the friction point half way. but if i drive rough it becomes rough and the friction point is very close the fully pressed... i dont know if a flush would help... that happenned since i loosened the nut that changes the height of the clutch...
1999, 5 Speed V6
mazen222
