SolaraGuy.com • View topic - Ignition Key
Ignition Key
Ignition Key
Postby hartman206 » Sat Jun 05, 2010 9:11 am
I put the key in and the ding ding starts but I can"t turn the Key. 2001 Solara - Black key - works on everything else ( door's etc). Put some graphite lube in... still won't work...any ideas ??
hartman206
Re: Ignition Key
Postby 99BlackSandv6 » Sun Jun 06, 2010 4:14 pm
Did you wiggle the steering wheel? Common problem is for the wheel to lock in position. It's an anti-theft thing.
If someone breaks into your car, it won't steer without the key. Just turn the wheel off the lock if you didn't try that.
