SolaraGuy.com • View topic - Yet another Headlight thread........
Postby SolAraB » Fri Jun 18, 2010 8:58 pm
Well it's been a while since i posted up on here, been working on an SC300 that i bought a few months back, but i have been having the most annoying issue with my headlight. My passenger side headlight has been acting up.
I have HIDs so first after a little investigating i changed the ballast, it worked for about 6 hours and then boom not working again. Then i changed my light bulb still wouldn't come on.
So today i messed around a little more and now i know that the bulb works, the ballast works, but it wont fire up on the passenger side. High beam works fine but low beam will not work!
I also re-installed a regular halogen bulb........same problem..........low beam doesnt work and high beam does. I even checked the fuses..... I am stumped..........someone , anyone please help!!
V6 5Spd....Injen W/CAE, Denso Ik22, Ngk Blues, TB Spacer, Twm SS, and of course CEL
SolAraB
Re: Yet another Headlight thread........
Postby TheGreenDutch » Sat Jun 19, 2010 7:46 am
check all your wiring to see if you have a short or something is exposed or crushed.
TheGreenDutch
Postby NightRider » Sat Jun 19, 2010 8:49 am
Yeah after what you explained. It seems you may have a short somewhere along the wiring.
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby SolAraB » Sun Jun 20, 2010 1:42 am
I guess i'll have to trace the wiring, i thought maybe it could be where the wires actually enter the black plastic connector that plugs into the bulb. BTW thanks a lot for the replies guys, i will let you guys know what happens..........
SolAraB
