SolaraGuy.com • View topic - So many CEL codes at once.
Postby vman5911 » Sun Jul 04, 2010 12:15 pm
I have a 2000 V6 Solara. Initially, I got a check engine light indicating that my EGR valve was probably faulty and that the position sensor was faulty as well. Soon after, I began to get error codes indicating that the oxygen sensor and air/fuel sensors were probably faulty. Soon after that, I started to get the Closed Loop Fuel circuit coolant temp insufficient code. Add that to random cylinder misfirings and you have a very, very frustrated person with a car that isn't running very well :(
I'm at a loss here, guys. It's starting to get to the point where I don't even know where I should start. Any advice would be immensely appreciated.
vman5911
Re: So many CEL codes at once.
Postby GreeKAvaLoN » Mon Jul 05, 2010 3:42 pm
start from the first code you got, work around the egr, see if u find anything wrong, pull the neg off the battery and reset the ecu and drive a bit. When i took my s/c off i ended up with like 14 codes. Some where like intake and egr and mass air blah blah. ended up i didnt tighten one bolt on my throttle body.. all well now! its probably one thing that spawned into a million little killer baby codes.
GreeKAvaLoN
Postby vman5911 » Mon Jul 05, 2010 7:36 pm
Thanks! That made me feel a lot more relieved.
vman5911
Postby TheGreenDutch » Tue Jul 06, 2010 9:08 am
Change your spark plugs and wires and do a Seafoam treatment if you haven't done this in a long time. Check your vacuum hoses for leaks or crud build-up. Is the CEL flashing?
TheGreenDutch
Postby vman5911 » Tue Jul 06, 2010 8:29 pm
The CEL flashes on occasion, but it doesn't happen often. The spark plugs are probably a good idea. Haven't changed those in a while. I recently seafoamed the engine, so I shouldn't have to do it again.
vman5911
Postby TheGreenDutch » Tue Jul 06, 2010 8:57 pm
I had bad plugs and went thru similar things. Change the wires too. They get old and cracked...
TheGreenDutch
Postby vman5911 » Wed Jul 07, 2010 7:19 am
Any recommendations on spark plugs?
vman5911
Postby TheGreenDutch » Wed Jul 07, 2010 10:06 am
Denso double platinum is widely recommended close to original equipment.
TheGreenDutch
Postby vman5911 » Thu Jul 08, 2010 11:19 am
The ones in the back are a pain to get to. I have the Chilton manual...any recommendations to get back there, or do I just work through the awkwardness?
vman5911
Postby navarachi » Tue Jul 20, 2010 8:56 pm
someone said they could do it without getting the header off, i couldnt. I'd just take it in, 100 bucks for a tune up is dirt cheap compared to the time you'll spend messing with those headers.
i just had the egr valve replaced as well.
good luck
navarachi
Postby SleeperSolara » Tue Jul 20, 2010 11:26 pm
The rear spark plugs are somewhat weird, but you can work your way around stuff if you have a small arm.
