SolaraGuy.com • View topic - seafoam smoke out of headers?
Postby mig0s » Wed Jul 28, 2010 6:19 pm
I posted this in the seafoam thread but no one bothered to read/reply...
Can someone explain/help?
I just did the seafoam with 1/2 to the brake booster, 1/4 to the engine and 1/4 to the gas tank. Everything went well and I got A LOT of smokes out of my exhaust... BUT also a significant amount of smoke out of my headers! It stopped after like 20 minutes when there's no more smoke from my exhausts. Is smoke out of the headers normal? Or is it a loose bolt or something? No CEL codes and car is driving really fine.
Thanks for your help.
mig0s
Re: seafoam smoke out of headers?
Postby solara90 » Wed Jul 28, 2010 6:26 pm
Like where the header mounts to the head? sounds like a bad gasket
02 solara 2az
solara90
Postby mig0s » Wed Jul 28, 2010 6:36 pm
solara90 wrote:Like where the header mounts to the head? sounds like a bad gasket
Yes there... do you mean I got a blown head gasket? I never had smoke coming out of my exhaust and the car is driving totally fine...
mig0s
Postby ThatVietGuy » Wed Jul 28, 2010 7:12 pm
He means the gasket that goes between the block and the headers (which is NOT the head gasket).
ThatVietGuy
Postby GreeKAvaLoN » Thu Jul 29, 2010 1:11 am
it pretty much means you got an exhaust leak. the headgasket goes between the block and heads.
GreeKAvaLoN
Postby mig0s » Thu Jul 29, 2010 8:14 am
and is it ok to continue driving like that? The smoke from the header gasket came out slowly so its not a big leak and it shouldnt be a big problem right?
mig0s
Postby ToyoSolV6 » Thu Jul 29, 2010 9:14 am
mig0s wrote:and is it ok to continue driving like that? The smoke from the header gasket came out slowly so its not a big leak and it shouldnt be a big problem right?
Personally i wouldnt drive it like that, but the gasket doesnt cost much, just go buy a new one take the headers off replace it, and your set.
Postby mig0s » Thu Jul 29, 2010 10:10 am
Can you do me a favor? Please find me the part I need on Ebay because I searched and I don't know what's the name of that specific gasket, so I just wrote "Solara gasket" and many different stuff came up.
Thanks a lot
mig0s
Postby TheGreenDutch » Thu Jul 29, 2010 12:36 pm
i'm guessing you need the Exhaust Manifold Gasket, but wait till one of the veteran guys chimes in tho.
http://motors.shop.ebay.com/i.html?rt=n ... 06.c0.m282
TheGreenDutch
Postby campfire9 » Thu Jul 29, 2010 5:20 pm
Unless you have actual headers which are different in that they are designed to take out exhaust gas as efficiently as possible, you are talking about an exhaust manifold leak. Toyota's come from the factory with exhaust manifolds. If that is the case, I would go to the dealer and get one to fit your car exactly.
Without ammunition, the USAF would be just another very expensive flying club.
campfire9
Postby mig0s » Fri Jul 30, 2010 8:46 pm
TheGreenDutch wrote:i'm guessing you need the Exhaust Manifold Gasket, but wait till one of the veteran guys chimes in tho.
Thanks for the help. Can someone confirm if this is what I need? http://cgi.ebay.com/ebaymotors/Beck-Arn ... 35aaf7fdc9
Or this?
http://cgi.ebay.com/ebaymotors/Exhaust- ... 3eff26dcfa
And thx campfire for the suggestion.
mig0s
Postby dug320 » Mon Aug 02, 2010 12:28 am
If the engine was cold when you started the sea foam process I would not worry too much. Sometimes tiny gaps can occur when the engine is cold and disappear as the engine heats up.
You can re-torque the bolts to tighten things up.
dug320
Postby mig0s » Mon Aug 02, 2010 8:09 pm
dug320 wrote:If the engine was cold when you started the sea foam process I would not worry too much. Sometimes tiny gaps can occur when the engine is cold and disappear as the engine heats up.
My engine wasn't cold at all... the smoke came out for like 20 minutes!
And guys, if the smoke came out of my headers, is this what I need?
Thanks!
mig0s
Postby TheGreenDutch » Tue Aug 03, 2010 12:46 pm
you know what if its not throwing a code then screw it man. I wouldn't worry about it. Its not going to hurt your car.
TheGreenDutch
Postby mazen222 » Wed Aug 04, 2010 7:38 pm
most probably it has been leaking for a while but you never noticed it since the smoke was light... now with sea foam i guess its white and more noticable. i dont see a problem driving with that except for pollution and noise. and it will most probably fade away as the seafoam and gunk burns outs.
its always best to replace it... gaskets are cheap.
where in mtl are u from?
1999, 5 Speed V6
mazen222
